Preamp output very weak
gerryt
Feb 5, 2021
46
I am attempting to repair a Yorkville KW100 (schematic attached). When I plug a music source into the return input which goes directly to the power amplifer section of the unit I get a clear loud musical output from the speaker. However when I plug the same music source into input channel one I get no output, and when I plug the same music source into channel two I get a very quiet output with the volume control for channel two turned up all the way. It is a weak signal but it is not distorted. I have replaced the op amp for channel two (U1 in the schematic) and tested the volume control for channel to be sure it is not faulty. I am a beginner in electronics repair and would appreciate any insights as to why I am getting such a weak signal from the pre amp into the power amp.
  • Yorkville-100KW-Power-Wedge - Schematic.pdf
Possibly overdriven the input with (not specified) whatever signal input you used.
Possibly damaged components.
again, no idea what you did here.......
You supplied a circuit diagram and then use your own terminology so no one has any idea what you plugged in where.
gerryt
Feb 5, 2021
46
Yes, I agree, I was not very clear about what I did, so I will attempt to describe with greater clarity. Played music from my CD player headphone output using a TRS 1/4" input into JB7 (return) Sound that resulted was loud and clear. Plugged same cable with same CD player source into JB3 and JB4 and turned 5B Volume 2 to full volume. Result is a barely audible but undistorted sound output.
......and did you notice the recommended input level ..???
What is your signal level..........???
