Hi,
I am using a Rumble 500 V3 bass amp in my rehearsals and, since recently, I am facing a problem with the quality of sound, it seems to be lost the presence. I will try to explain the problem
- Keeping all the controls flat, and no activating bright button, with no active mode only passive, high frequencies have gone.
- I have tested the horn (tweeter) and it has 6ohms and seems to be working, when I connect a music source to the amp the horn seems to be active although music has a very low volumen in the horn, almost imperceptible but you feel whether it is connected or not.
- Equalizer (Preamp) works, in order to compensate the lack of high frequencies I have to activate BRIGHT button and increase a TREBLE
- The rest of the AMP (Power) works fine.
- It is not a problem of strings (I have changed them few months ago)
I thought that crossover could the reason, so I am looking for the components (cap 1uF and 8.2ohms 5W) to replace them.
Reading in this forum but related to Rumble 150 and another problem, I read a comment from a member of the forum that electrolitic capacitors could be the reason of bad audio quality, so I decided to explain here my problem.
I have the schematics but I see several electrolitic capacitors and I am not sure to change all of them,
Any idea, comment or suggestion will be much appreciated. Thanks in advance
