rennervision
- Jan 29, 2024
- 5
- Joined
- Jan 29, 2024
- Messages
- 5
Hello. I have this 25-year-old collectible... bottle(?) - for lack of a better term - that's been giving me some trouble lately.
Inside is a small PCB that powers four Christmas tree lights (via three AA batteries) when you push a button on the front. The way it works is the circuit is complete when the button is NOT pressed. This is a normally closed push button, so pushing it interrupts the circuit, then the button springs back into its default position. This prompts an electronic timer on the board to allow all lights to illuminate for 30 seconds. (The same thing would happen if I replaced the batteries; since I briefly interrupted the circuit, the lights would again activate for 30 seconds.) I assume the 30-second timer is a safety feature so the bulbs don't start to melt the plastic inside.
Anyways, two years ago it stopped working and I was able to find someone online to build a replacement PCB for me. Although I assumed that would be the end of it, now the new board is giving me problems. This time the issue is very intermittent. Sometimes the lights do not shut off after 30 seconds. Two+ minutes will pass and I then have to remove the batteries to turn out the lights.
I’ve also noticed the bottle lighting up on its own. (I didn't press the button.) And then it keeps shutting off and turning back on by itself until I remove the batteries.
I’ve provided some photos of different angles of the components. My apologies as I don’t know much about these electronics, but I'm sure I can swap out anything on the board. Would anyone know which part needs replaced to get it operating reliably again?
Thanks for reading.
Thanks for reading.
