nor did I get any ohms from it.
Meaningless. Show where you made a measurement, how you did it and the results you got.I tested it from two positions of the only switch I found on it.
In the pic with the terminals is where I connected a multimeter. I don't know any other way to test ohmsMeaningless. Show where you made a measurement, how you did it and the results you got.
A 24V device won't work with an 18V battery. At best it will cause an over-current situation and the built-in battery protection would cut off the power from the battery anyway.
The battery terminals may not even match.
As far as that other switch, duh. Didn't see the forest through the trees. I'll take your advice in a bit here and report back...I couldn't fathom the images you posted - until now! Now that I 'see' what you've done you say you aren't measuring anything across the terminals where the genuine battery should connect? Is that with the switch in the run position? If so then maybe the switch is defective or the motor is open circuit.
The motor is potentially a brushed commutator and the brushes likely worn to the point of none contact so they would be another thing to check. Replacement brushes should be readily available.
Still, those portable tool batteries have internal over-current protection and may be cutting off - simple tes though, measure the battery voltage whilst switching the thing on. If it stays the same then the motor/switch need checking.
I assume so or binary switch. My eyes are bad, but it's that lever and a "power/quiet" switch on the top there.Is that a throttle?
Would a variable power supply over 24v be a useful tool? I think mine broke, want to order another for general testingyeah, I figured that was possible, planning on getting fatter wires. Okay will be back later...If that motor ever starts running those croc clips/wires will be smoked almost immediately!
Assuming a 'throttle' then we're looking at PWM speed control. This is adding another layer of stuff between the battery and the motor and another potential point of failure. Time to take the covers off and look closer.
The Worx mowers use brushless motors with 2 x 40v batteries, most likely lithium or LiPo.The motor is potentially a brushed commutator and the brushes likely worn
Where did you get the info and why do you say 40v and not 24v?The Worx mowers use brushless motors with 2 x 40v batteries, most likely lithium or LiPo.
So therefore brushless motor controller and not much point poking around trying to measure resistance with a multimeter.
This is the WG782. I couldn't even find it on their site.What model is it?
The WG778E uses 2x20v = 40v.
Show a picture of where the battery or batteries slide on.
Also quite possibly has two ‘dead man’s’ switches so only can be used with two hands.
No, don't have a battery. Just found the mower on the side of the road, figured I'd see if I could test it then sell it. Thanks for the link.That model is indeed a 24V lead acid battery.
I believe it dates back to about 2012?.
The battery looks to be quite large too. Do you have the old battery to supply us with the specs?
Edit:
Battery = WA3216, 24V, 5Ah
Charger = WA3721
I do! I have m12 and m18 Milwaukee batteries. Didn't think of that.If you have two 12V batteries, connect them in series.
