so the information on the Beacon Light says
- Mounting: Permanent Lens Design: Round Light Output: 33, 000 Candela Watts: 70.8 Base Material: Stainless Steel Housing Material: Aluminium
Number of Light Sources 2 Voltage 12 Volts Included Components Two Sealed-Beam Lighting Method halogen
8.7 wattsWattage Manufacturer Part Number 76223
as for the plug it say
Brand LINKSQ Connector Type 2-Pin Compatible Devices Projectors, PC, Game Consoles, Musical Instruments, Printers Compatible Phone Models Google Pixel Special Feature Short Circuit Protection, Over Current Protection, Over Voltage Protection Color Black Input Voltage 110 Volts (AC) Mounting Type Wall Mount Amperage 6 Amps Wattage 72 watts
the set up i am thinking is to splice together a 8 AWG wire to the 16 AWG from the Beacon light and then extend the wire to about 35 to 40 ft long the reason for the thicker wire because I heard that the longer the wire the more there will be a voltage drop so to prevent voltage drop I wanted to provide a thicker wire and so 8 AWG should be suffice for the length. I will then splice together another short length of 16 AWG because the female adapter part for the AC/DC plug only can fit a 16 or 12 AWG wire and then that would plug into the AC/DC adapter which I already gave the specs on this would then plug into a surge protector so that there is an off and on switch for it so that it could be turned on and off whenever needed
