cheap cnc milling machine not controlled by computer
Maglatron
Jul 12, 2023
2,025
Hi guys it's me birthday :) anyone know of a cheapish cnc miller that can be controlled by a keypad or buttons rather than a computer, for metal? thanks
Minder
Apr 24, 2015
3,561
In a CNC machine, the PC or processor of some kind provides two things, one it closes the trajectory loop for the motion control, and also has another processor that takes care of the other tasks such as work coolant sys, tool changing, and any other electro-mechanical function required.
Not sure how you would achieve this without an intelligent processor of some kind?
Minder
Apr 24, 2015
3,561
Check over at the CNCzone, they have several forums on small machines.
The cheapest way to get into it is a M/C that uses a PC and free initial version S/W such as Mach3
Maglatron
Jul 12, 2023
2,025
I didn't find that very helpfull but am thankfull for the suggestion anybody else?
Minder
Apr 24, 2015
3,561
That machine is about the most basic you are going to get, It uses steppers and Arduino controller with GRBL CNC S/W.
You could pick one up and improve the rigidity, otherwise for anything heavier, you will pay more.
The old adage 'You Get What You Pay For" applies.
Maglatron
Jul 12, 2023
2,025
thanks can you point me to the miller you are refering to, cheers Mr Minder
Maglatron
Jul 12, 2023
2,025
so do you have a machine that runs with arduino please Mr Minder, thanks
Minder
Apr 24, 2015
3,561
The Youtube one you referred to
I used high end Galil PC CNC motion cards for my DIY builds.
Other than that, I retro-fitted machines using Mitsubishi CNC controllers for a living.
Maglatron
Jul 12, 2023
2,025
I want to de-wire a rotor from a washing machine motor and mill out a rectangle on either side, 40mm wide 15mm deep (in towards axle) and 27mm the remaining direction the picture plates with holes are acctually neo 52 and they and 40mm x 13.5 x 5mm!!! will the miller in question be up for the job??
Minder
Apr 24, 2015
3,561
What the heck are you attempting with the rotor/armature?
danadak
Feb 19, 2021
1,100
Its odd, you ask for a CNC, then insist it not be CNC (Computer
Numerical Control), emphasis on no computer.
So minder and I have shown you low cost CNC, and you seem to have confirmed that in post #6,
is it safe to say NYET to CNC-less machine ?
Maglatron
Jul 12, 2023
2,025
well thats because I don't really know what I'm on about maybe I don't need it to be computer controlled, after thinking about it I think I just need a manual miller if that is a thing
I want to mill out a retangular shape 15mm deep x 27mm x 40mm in the armature after stripping it of the wire and removing the comutator and do the other opposite side too and secure the magnets and I'm turning the motor into a generator so when the shaft is spun the the stator coils will energise prodiucing ac current - it's a conversion of motor to generator! it might be the right time to say I have never used a milling machine of any sort!
Maglatron
Jul 12, 2023
2,025
so I found these which might be better to suit my needs but I think they're a bit too small and expensive
what do you guys think?
