Hi all,
I recently aquired a Panasonic TH-60CX700Z.
When plugged in it turns on, displays the text "HDMI 16:9" and then mediately shuts off and I can hear the relay cut out.
I have replaced all the caps on the cold side of the power board with no luck, none of the caps appear to be damaged or swollen, I have tried disconnecting everything but the main board and the problem still persists so I believe the problem is with the power board, however I don't know what components to check/replace.
Any help is appreciated.
Thanks.
Thanks.
