LCR-T4 replacement display ideas wanted
Sidecar Bob
Dec 19, 2021
270
Quite a while ago I ordered an LCR-T4 transistor/diode/capacitor &c tester. When it arrived the top left corner of the display was chipped and the top half of the display was blank. I received a working unit a few weeks ago so I do have one to use myself but I got thinking about whether the display could be replaced so I could give it to someone else.
I found the original display on Aliexpress but it is no longer available
https://www.aliexpress.com/item/32816995325.html?spm=a2g0o.seodetail.topbuy.1.1ea15721fEnQ7i
I found this display that looks the similar to me but I know very little about these things
https://www.aliexpress.com/item/32899426354.html
I also found this article about upgrading the display but he doesn't give many detains and I have no idea how to connect the display he used
http://eessential.blogspot.com/2018/12/lcr-t4-transistor-tester-display-upgrade.html
Am I pursuing untamed aquatic birds again or is this something worth attempting?
Bluejets
Oct 5, 2014
7,374
Looks like an Oled display...even if compatible, soldering of that very fine pin pitch would be normally a solder flow robot job.
Good luck with a 40w bench iron.
Sidecar Bob
Dec 19, 2021
270
Do you mean the original type display or the one Eesential used?
The original one plugs to a connector on the board...
kellys_eye
Jun 25, 2010
6,512
You need to check all the datasheets for 'any' 64x128 dot matrix display and see if the various data lines match the existing display. I suspect that most 'non-onboard-controller' displays will have similar if not identical connections - not necessarily in the right order though! - and that a replacement could be fitted. Something larger might also improve the usage.
Sidecar Bob
Dec 19, 2021
270
The display has what I would call a flexible PCB (maybe there is a newer name for this?) that connects to the board plus a pair of leads for the LED. Looking behind the display from the end without unsoldering the LED leads on Monday I thought I was seeing the contacts on the flexible plugged into a low profile set connector similar to ones I've seen inside laptops. Today I unsoldered the LED leads and as you can see the flexible PCB is soldered to the main board. I don't think unsoldering it and soldering on a new one would be beyond my abilities with my WTCPS soldering station and a small tip (old tech but still very good)
I contacted the seller of the display that I thought looked similar (2nd link in post #1) and they said it will work with an LCR-T4. Now that I can see where it connects to the main board I can tell that it has the right number of pins and the spacing matches so I ordered one.
Oddly the one in the first link (available again) now shows a lot more than the required 14 pins so it won't work. Maybe it's a good thing I missed it.
BTW: Here is what the damaged display looks like
Bluejets
Oct 5, 2014
7,374
Whole thing is only $20 odd....better still, spend a bit extra ($30) and get one in a case.
Sidecar Bob
Dec 19, 2021
270
It came to under $12 Canadian for the display & case and the tester would otherwise be scrapped so that's not bad.
kellys_eye
Jun 25, 2010
6,512
The number of pins actually used is the same as the other device - it can probably be used but would require a lot of individual wires to be soldered between display and board.
As per the above, at $12 these are 'disposable' items and I have THREE (one in use - cased - two [actually ordered in error!] kept as spares). Not worth the effort and expense imho.
Sidecar Bob
Dec 19, 2021
270
When I said "it won't work" I meant it cannot be a direct replacement.
$12 is what I paid for the replacement display and a case to mount the unit in, including shipping.
Complete units (tester + case) average around $20-30 Canadian depending on where you buy them. I paid about $20 for the first one on eBay 6 months ago but the same item from the same seller is now almost $30.
Assuming that the display I have ordered is a direct replacement and my time is free that sounds like a bargain to me plus I get the experience of replacing the display.
As for "disposable" and "not worth the effort and expense", that is one of the biggest problems our society faces these days. I agree that sometimes it makes more sense to replace something than to repair it but we throw out too many things that could (should?) be fixed and that results in the landfills filling up (don't be fooled: a substantial amount of what we sent to e-waste ends up in landfills after the materials that are easy to harvest are removed).
BTW: Instead of buying a succession of newer vehicles every few years I bought that 39 year old motorcycle in my avatar pic as a non-runner and it has been my daily driver for the last 25 years.
Sidecar Bob
Dec 19, 2021
270
The display and the case arrived on Friday (19 days before Aliexpress said it would arrive). And we have a Heat Warning (= seniors & dogs should stay indoors or go somewhere air conditioned) so I had to find a project to work on indoors. Perfect timing.
The new display looks exactly the same as the original except that is blue instead of green.
Replacing it was easy. The last pin on the left isn't soldered to the board so I gently lifted it while heating the solder on the next one and when that one lifted I moved to the next & so on.
Soldering the new one on was even easier. The biggest issue was that I damaged one of the pads for the LED when removing the old one and didn't notice until the new LED didn't work but an inch of wire fixed that :rolleyes:
When I was putting the first case together I found that the nuts & bolts included for the corners were too long so I had to dig around to find something that would work and in the process I dropped the back of the acrylic case on the cement floor in the garage. Amazingly I found all of the pieces so I glued them back together with ACC and sprayed it with gloss black appliance epoxy.
The extra tester is going to my brother in law so I had planned to put the tester I repaired into the case I repaired so that his will be in original condition.
When the repaired tester's display turned on and I saw that it is light with a dark background that only confirmed my decision.
Original (left, green display) and my "customized" version (right). To my eyes the green display looks sharper in the pic than in person and the blue one looks sharper (picture all the gray as the lighter shade).
BTW if anyone is counting the total cost of the 2 testers was about $43.50 CAD (approx. $33.65 US).
And that's including the money that the seller that sent the one that arrived damaged never did refund.
Sidecar Bob
Dec 19, 2021
270
So 3 years in there's just one thing about the LCR that I find annoying: The connector for attaching components is OK for small stuff but for anything too big to fit you have to stick wires into the connector and use clip leads to connect to the component. I was doing that yesterday when I thought it would be easier if it had somewhere to plug in test leads with banana plugs.
Hmmmm.... How hard would it be to add a couple of those binding posts?
Now that's better
Harald Kapp
14,306
Not hard at all. Solder wires to the respective pins at the bottom of the zip sockte. Connect the othe rend of teh wires to your preferred connetor option.
Sidecar Bob
Dec 19, 2021
270
Um, if you look closely at the picture I posted you will see that is almost exactly what I did.
I thought about mounting the binding posts on the front but you have to remove it to access the battery so I decided to put them where the wires won't have to move.
There are a set of pads on the board that appear to be for holding transistors against for testing but are inaccessible when the unit is mounted in the case so I used them instead of removing the board to get at the back of the connector.
There isn't a space big enough for 3 of those binding posts together (there's barely enough room for 2 where I put them) but most large components only have 2 terminals. I can add another on the other side if find that I ever need it.
I started by undoing the 4 screws and removing the front panel so that I could lift the side out, then drilled 2 holes in the side and mounted the binding posts.
I soldered wires onto ring lugs, attached them to the binding posts and fed them under the board to come out near the set of pads and soldered the wires to #1 and #3.
