"Safe" 5000 V
Y
Yevgenip
Jan 1, 1970
Is there any way to make high voltage sparks that will not kill anyone?
A
Alun
Jan 1, 1970
Yes, thats true, if you design a high voltage power supply with a high internal impedance then the output current will be too low to kill. For example if a 5KV supply has an internal impedance of 5M then the closed circuit current will be only 1mA
sec
Mar 15, 2004
15
Alun has explained the theory pretty well, but on the practical side, you'll want to build something like a Van de Graaf generator, or a Tesla coil. Search around on the Internet; there are plenty of resources out there.
A forum dedicated to these (and other) HV topics can be found at http://forum.4hv.org/index.php
A
Alun
Jan 1, 1970
ok back on topic,
I don't consider Tesla coils a safe source of HV, Van de graff generators are.
You can make also safe HV source by driving a fly-back transformer at 10KHz and conecting the output via a high voltage capacitor to limit the current.
Y
Yevgenip
Jan 1, 1970
Anyone knows what dragon ball Z is? I thought about making two gloves that will fire sparks from one to another, but was scared I might kill some one.
steven2
Jan 19, 2004
1,698
:Dwelcome to the high voltage stuff section even 250 volts was conciderd high voltage still so if you want sparks or arcs that dont kill try the push button ignitor from a gas stove, whatever its voltage is im not sure
A
Alun
Jan 1, 1970
As I said in my previous post, if you limited the current to a safe level you wouldn't cause any injury or death. Never the less I don't think you're glove idea is any good because the insulation on the gloves would have to be very thick to stop the electricity passing through the wearer.
danieleredivo
Jan 5, 2006
2
Let's do some calculation: to make a spark between the two gloves, let's say they are 0.5 meters apart from each other, since dry air discharge break voltage is 3MV per meter, you need a 1.5MV = 1500 V (DC voltage) between your hands. I wouldn't play so close to it. Besides 5000 V seems to me extremely exagerated to obtain the spark.
regards
audioguru2
Apr 6, 2004
12,026
regards
Half of 3 million volts is 1.5 million volts, isn't it?
It isn't exaggerated. There is a link on another post to a 1 million volts DC thingy that produces arcs Four Feet Long! It uses four TV flyback transformers in parallel to power its voltage multipliers. I don't think anyone wants to be anywhere near it.
danieleredivo
Jan 5, 2006
2
ooops, sorry I've mistaken then units. I correct my last post: for 0.5 m spark you need 1.5MV = 1500 kV = 1500000 V, so with 5000 V you can get a spark of almost 2 mm.
regards
