Y
Yevgenip
- Jan 1, 1970
- 0
Is there any way to make high voltage sparks that will not kill anyone?
As I said in my previous post, if you limited the current to a safe level you wouldn't cause any injury or death. Never the less I don't think you're glove idea is any good because the insulation on the gloves would have to be very thick to stop the electricity passing through the wearer.Anyone knows what dragon ball Z is? I thought about making two gloves that will fire sparks from one to another, but was scared I might kill some one.
Half of 3 million volts is 1.5 million volts, isn't it?danieleredivo said:Let's do some calculation: to make a spark between the two gloves, let's say they are 0.5 meters apart from each other, since dry air discharge break voltage is 3MV per meter, you need a 1.5MV = 1500 V (DC voltage) between your hands. I wouldn't play so close to it. Besides 5000 V seems to me extremely exagerated to obtain the spark.
regards
A piezo lighter.danieleredivo said:so with 5000 V you can get a spark of almost 2 mm.
