The brain itself is a computer. And researchers have already connected living brain cells to real computer systems.
A. “DishBrain” (2022-2024)
Scientists grew about 800,000 neurons in a dish and connected them to a computer interface. Those neurons:
- learned to play Pong
- adapted to stimuli
- improved over time
They acted like a biological processor.
B. Brain–computer interfaces (BCIs)
Devices like those from:
- Neuralink
- Blackrock Neurotech
- BrainGate
take signals from neurons and use them to:
- move a robotic limb
- type on a computer
- control a cursor
Here, the brain is commanding the computer using electrical signals.
C. Brain organoids
Mini “brains” grown from stem cells can:
- perform pattern recognition
- respond to inputs
- store short-term memories
These are being tested as biological computer chips (“organoid intelligence”).
Researchers have already built:
- neuron-based pattern recognizers
- memory-storage circuits made from neurons
- logic gates using living cells
The human brain is:
extremely powerful (~10¹⁵ operations/second equivalent)
massively parallel
ultra-low-energy (20 watts vs. 150,000 watts for a supercomputer of similar scale)
The brain is astonishingly energy-efficient—billions of times more efficient than the best modern chips. It runs on about 20 watts, yet performs computation comparable to a supercomputer using millions of watts.
1. The brain uses “event-driven” computing, not constant clocks
A modern CPU/GPU:
runs at a fixed clock (3 GHz, 1 GHz, etc.)
toggles transistors billions of times per second whether or not there’s useful work to do
wastes huge energy on timing, synchronization, and leakage
The brain does none of that. The brain is
asynchronous:
A neuron fires only when needed
If nothing important is happening, it consumes almost no energy
No global clock exists; each cell acts independently
This saves an enormous amount of power.
2. Neurons compute with ions, not electrons
Modern chips push electrons through metal wires, causing:
- heat
- resistance
- leakage
- electromagnetic noise
- energy lost per switching event (~10⁻¹⁵ to 10⁻¹⁴ joules/transistor)
The brain uses ion flows across membranes, which use:
- slower chemical gradients
- minimal leakage
- very low voltage (~70 millivolts)
- energy costs on the order of 10⁻²¹ joules per “switch”
That’s a million times lower energy per operation.
3. The brain stores memory in the same place it computes
Modern computers use:
separate memory (RAM)
separate processors (CPU/GPU)
expensive data movement (the von Neumann bottleneck)
Moving data costs far more energy than computing on it.
In the brain:
- memory = synapse strength
- computation = neuron firing
- they are co-located
- no shuttling data back and forth
This is one of the biggest reasons the brain is so efficient.
4. The brain does massive parallelism, not fast serial computation
CPUs and GPUs do:
a small number of extremely fast operations
- billions of clock cycles to do a task sequentially
The brain does:
millions of tiny, slow operations all at once using billions of parallel units
It’s like the difference between 10 workers digging fast vs. 10,000 workers digging slowly — the latter is far more efficient for many tasks.
5. Biological “hardware” has built-in adaptability
The brain uses:
plasticity
synapse rewiring
selective strengthening/weakening
local learning rules
This allows the brain to reroute processing dynamically, removing wasted energy. Silicon must brute-force everything and recalculate constantly.
6. Neurons can transmit analog information
Digital chips:
encode everything as 0/1
require high precision
lose info and must refresh memory constantly
pay huge energy costs for noise-free switching
The brain:
uses analog signals
allows noise
uses probabilities
only needs “good enough” precision
doesn’t refresh memory like DRAM
adapts wetware pathways instead of reprocessing everything
Analog computation is far more energy efficient for many tasks.
7. The brain uses predictive processing to minimize work
Evolution discovered that perception is efficient if you:
- predict what will happen
- only compute the “error”
- suppress redundant information
Your brain does this constantly:
- in vision
- in hearing
- in movement
- in thinking
It avoids recomputing the whole world from scratch — saving energy.
This is one reason hallucinations happen: the brain relies more on prediction than raw input.
8. Evolution optimized the brain for energy, not speed
Human ancestors with larger brains needed more calories.
Energy efficiency meant survival.
Silicon chips, by contrast:
were optimized for speed
not energy efficiency
not biological constraints
powered by external electricity, not survival limits
9. Neurons operate at low temperature
A modern supercomputer:
requires massive cooling
is limited by heat dissipation
loses energy as thermal noise
The brain:
operates near body temperature
uses slow, low-voltage signals
performs computation with minimal heat output
The body’s cooling and blood flow handle the rest.
The brain is so energy efficient because it:
- computes only when needed
- uses ion gradients instead of electrons
- merges memory and computation
- performs huge parallelism
- adapts dynamically
- uses analog + probabilistic signals
- predicts rather than recomputes
- evolved under strict energy constraints
- computes at low temperatures
Overall:
The brain is 1,000,000–1,000,000,000 times more energy-efficient than modern computers for the types of problems it solves.
