Chrisraven4321
- Jan 1, 2026
- 15
- Joined
- Jan 1, 2026
- Messages
- 15
Theory question, if anyone would like to put in their thoughts. I have been out of the electronics world for a while now and my memory fails me on the following. On the attached drawing there are 2 transistors Q119 and Q121 which is marked as a differential preamp. The signal comes in through the "input from the generator" jack and exits into the speakers on the right of the drawing. While the normal path trough an amplifier is fairly straightforward, this little addition of Q121 has me slightly confused as to how the signal is passing through. Some input would be nice especially if you can give me an idea of the amplification levels through the various stages. Plus how the signal is processed via the different stages. Hope I asked this in a logical manner.
Just another quick request. The capacitor that is connected to the speakers is showing a + sign on both sides of the capacitor. Which side do you think should be the positive and which side should be the negative? I have +35 volts on the top and -35 volts on the bottom, this is the basis for my question.
Thanks
Chris
Thanks
Chris
