Unknown electronic symbol
carloncho
Sep 2, 2018
Hallo comunity,
in a circuit diagram of a SMPS there are symbols D1 -D8 (see annex) which I dont know. Can anyone tell me what is the meaning and purpose of them.
Thanks in advance for any answer.
Carloncho
  • IP Board Schematic.pdf
14,487
I assume you don't really mean D1 - D8 as different types of diodes are referred to
I suspect you really mean D1,D2,D5,D6,D7,D8,D19 and an unmarked one in the top right … prob. D9
They are a twin diode pack
where the cathode of one diode is commoned with the anode of the other diode
I would have to search for a specific part number
are you sure it isn't already listed somewhere on the circuit sheet ?
Externet
Aug 24, 2009
944
Can be the lower right connected as counterparalleled, A1 to K1.
iu
When 'circled' can mean LEDs :
73's de Edd
Aug 21, 2015
3,730
Sir carloncho . . . . . .
Are you just grasping for straws in zeroing in on those parts, as being at fault?
The schematic shows the 8 sets to be current and voltage sampling for the 4 (or more) CCFL backlight lamps and feeding back correction to the OZ960 CCFL controller .
Give your specific SAMSUNG model number and more info can be forthcoming.
With the board connected back into the unit and then plugged in and powered up . . .is 13VDC power present at the R15-R13 junction feeding pins # 3-4 of the OZ and pin 3 of each of the 4539 power driver FET's ?
PARTS DATA . . . . . BAV99L
73's de Edd
