Hello everyone, I'm a PCB beginner and recently encountered a problem I'd like to ask you all:
I have an LED board, and one of the LEDs is visibly burnt out, causing the entire board to stop working. The power supply seems normal, and the wiring doesn't appear to have any obvious breaks. What could be causing this?
I'd like to repair it myself, and I have a few questions:
Will simply replacing the burnt-out LED restore the board to normal?
What parameters and specifications are needed for the replacement LED?
Besides the LED, could the problem be with the driver, the wiring, or other components?
What precautions should I take when soldering to avoid burning it out again?
I'm new to PCB design and my basic knowledge is weak, so I would greatly appreciate any guidance from experienced PCB developers. Thank you very much!
