Cordovox piano G keys dead
roughshawd
Jul 13, 2020
616
I don't know what this is. Looks like a hairline fuse someone put in it.
Just a scratch. ..
This is the tone bar board. There was a shielded, green wire, that may have bent over shorting across these components
roughshawd
Jul 13, 2020
616
Just a scratch. ..
roughshawd
Jul 13, 2020
616
Black wire pinouts at the chips read pin to pin 3.3k, except one. Pin 11 reads 44.2
roughshawd
Jul 13, 2020
616
A hair out of the horsetail is disconnected from the do Re Mi panel...
Would really like to take a vacation when this is working again....
ps. Everything else is checking out ok!
roughshawd
Jul 13, 2020
616
I fixed the scratch... Made a better ground, and found a loose wire in the key switch pins. I have infinite on the -9v +9v And +12 v ok. I am out of expertise.. I am not college educated.... What would cause my -9v rail to go infinite?
roughshawd
Jul 13, 2020
616
I found the board had a large scratch in it that broke through the trace across one of three traced affected. I repaired the broken traces with a solder jump.
roughshawd
Jul 13, 2020
616
This system uses a -25v rail instead of a -9 or -12v. Testing with my 20v setting on the vom would read infinite.
roughshawd
Jul 13, 2020
616
Now here is the intonation board...
Why do the trims all read 3ohm when they have 2k2 written on them?
roughshawd
Jul 13, 2020
616
Voltage across the caps, seems nominal...
With resistance tests, no power, I have 3 electrolytic caps which test outside of 200k #27, #37, and #51. The last one, #50 if I include the axial reference.
roughshawd
Jul 13, 2020
616
Time to get serious.....
Under the tone control is my worst failure... The power board.
roughshawd
Jul 13, 2020
616
The power board
roughshawd
Jul 13, 2020
616
The board was scraped through one of the traces... I did a repair, but I don't know if it will work... to scared to test it...
there was a wire to the main process board which was disconnected, I don't know, maybe the repairman did a check for something and didn't find anything, the in trying to get a signal, realized it was a bad wire.... I am a horrible pessimist! should I test it... yes|no...no|yes...
I should test it.... no no... yes yes... nono. yesyes...
toss a coin? spin the wheel? test or not to test... that is the question....
Ok. enough... the suspense is killing me!
