roughshawd
- Jul 13, 2020
- 618
- Joined
- Jul 13, 2020
- Messages
- 618
Just a scratch. ..,.I don't know what this is. Looks like a hairline fuse someone put in it.
Just a scratch. ..I don't know what this is. Looks like a hairline fuse someone put in it.
This is the tone bar board. There was a shielded, green wire, that may have bent over shorting across these componentsI don't know what this is. Looks like a hairline fuse someone put in it.
Just a scratch. ..
The "rail" being the shared ic power lineI put the screw in, closed the lid, nothing works...
There is 4.5v on the +9 IC rail....
I found the board had a large scratch in it that broke through the trace across one of three traced affected. I repaired the broken traces with a solder jump.I don't know what this is. Looks like a hairline fuse someone put in it.
This system uses a -25v rail instead of a -9 or -12v. Testing with my 20v setting on the vom would read infinite.I fixed the scratch... Made a better ground, and found a loose wire in the key switch pins. I have infinite on the -9v +9v And +12 v ok. I am out of expertise.. I am not college educated.... What would cause my -9v rail to go infinite?
Test & take a photo of the part of the board that smokes…test or not to test... that is the question....
Ok. enough... the suspense is killing me!
