Hi everyone,
Been a while since I last posted. Hope you are all well.
I've just repaired a NAD 3130 stereo amplifier which had a blown OT and I one of the drivers. It seems to be working fine but I was bored this eve and decided to check the alignment according to the instructions on p4 in the service manual (which I have attached). The centre voltage was fine but the idling current test was reading 200-300mV on both sides as opposed to 26-30mV given in the manual. The manual says adjust RX1 and RX2 to get the right current in the collector but on the actual board this is not a pot but a regular fixed value resistor on both sides (in parallel with another (R454 and R453). Given that that I need to reduce the collector current on both the left and right sides, should I be making RX1 and RX2 higher or lower? The schematic is on pp9-10.
Sorry if the question is a bit simple - I have fixed a number of amps and built guitar valve amps but my knowledge of solid state push-pull AB amplifiers (which I believe this is?) is limited.
Thanks in advance for your help.
Cheers
Tom, UK
Cheers
Tom, UK
