When your PCB real estate is extremely tight, leaving no room even for a conventional USB port. Beyond the main MCU solution, you also need to account for the PCB footprint occupied by the charging management chip. How do we deliver power for compact wearable devices under these conditions?
Many hardware teams hit this bottleneck during wearable development and consider using traditional pogo-pin connectors. However, from my experience with wearable products adopting this solution, exposed charging contacts tend to corrode over time due to sweat, cosmetics, or oil contamination.
Is there a solution that can handle both data transmit-receive functions and charging management to save PCB space? The NFC-WLC solution uses a tiny PCB coil to harvest energy from a 13.56 MHz magnetic field while supporting bidirectional data communication. It eliminates the PCB space required for pogo-pins or Type-C ports. It also simplifies mechanical housing design and reduces risks of mechanical wear and liquid-induced corrosion.
