Ultrasonic Welder for thin LDPE? Or maker space that has an ultrasonic welder?
YogaDadAZ
May 3, 2024
I need to weld a thin film (0.007") of LDPE to a solid cylindrical piece of Polyproylene (PP) for a prototype part. The weld pattern will be an annular ring (O.D.=1.8", I.D.=1.5"-1.6") on each end of the cylinder. The joint has to be welded, no solvent or glues. The purpose of the weld is to create a water-tight seal (up to 100 p.s.i.).
I've seen inexpensive (~[imath]300), handheld ultrasonic welders advertised, but the horns on these models are very small and would require me to manually move the device around my prototype in order to create a continuous, welded seam. After that, the prices of ultrasonic welders jump to[/imath]1000 and much higher. Does anybody have any experience with these low-cost ultrasonic welders? I haven't found any maker spaces that have ultrasonic welders and I don't want to shell out $1500 just to make a few prototypes.
Any thoughts or recommendations would be greatly appreciated.
Your requirements outlined are specific to specialised equipment, not only the welder but the mechanism to hold the workpiece and move to required locations.
Suggest you contact a manufacturer.
...or use a "really good" o'ring and compression sleeve.
YogaDadAZ
May 3, 2024
Thanks. I've already built an o-ring configuration to prove viability and it worked. Now I'm trying to demonstrate a high volume manufacturing solution.
bidrohini
Feb 1, 2023
221
Using a specialized heat sealing tool designed for plastics can provide a more consistent seal.
