audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
Hi Kevin,
The voltage regulating zener diode, D8, is in the feedback loop of the very high gain opamp, U1, and together make a very good voltage regulator of 11.2V. The high gain of the opamp makes certain that the current through the zener is constant, regardless of how much the supply voltage is fluctuating. Since the zener's current is constant, the output voltage of U1 is also constant. The 5.6V zener was selected because a zener of that voltage has a low temperature co-efficient.
The negative voltage regulating zener diode, D7, does have a voltage change due to transformer voltage variations and system output loading, but that has no effect on the system's output voltage.
