audioguru2
- Apr 6, 2004
- 12,022
- Joined
- Apr 6, 2004
- Messages
- 12,022
R9 feeds the adjusted reference voltage to U2 and limits the loading effect of C4 on the output of U3. If its value is higher then U2 might pickup interference. If its value is lower then U3 might oscillate due to C4 being at its output or R9 won't discharge C4 quick enough during current limiting.jiangrm said:1. How to decide the value of R9? Why don't we use 10K or 470R?
It is a supply bypass capacitor for high frequencies, because C1 is so big it has high inductance. Analog electronic circuits oscillate without it or if its value is too low.2. What's the purpose of C5? How to calculate the value?
C5 could be 0.1uF to about 1uF and a ceramic disc is best at high frequencies.
Yes, because Q2 and Q4 are in its negative feedback loop and are much slower than U2 and cause delay, the combination could oscillate without C9.3. Is C9 used to improve the stability of U2?
U2 oscillates if its load is capacitive and is directly at its output. R15 isolates the capacitance of Q2 and I recommend reducing its value to 100 ohms.4. Can I connect output(pin6) of U2 to base of Q2 (bypass R15)? If not, why?
Connect the 0V output to ground and the project supplies variable positive voltages above ground.5. If the system should be grounded, which part of the circuit should connect to ground as well?
Connect the Positive output to ground and the 0V connection supplies variable negative voltages below ground.
Don't ground any part of the output and the project can be connected in series with another supply that might be grounded.
