0-30 Vdc Stabilized Power Supply
12345678
VCC is +-22 have a look at this datasheet.
its a 27V AC transformer handmade by me.
we will see what comes out after i test it.
now i will go to bed. its 4:52 am.
thank you
155643-da-01-en-OP-VERST_UA741CD_STM.pdf
  • 155643-da-01-en-OP-VERST_UA741CD_STM.pdf
audioguru2
Apr 6, 2004
12,022
You are correct. I didn't know the max voltage is different from different manufacturers. It is only 36V max from National Semi and Texas Instruments.
27VAC at full load will rise to about 28.5V without a load.
27VAC makes 41.8VDC adding the positive and negative supplies.
28.5VAC makes 44.5VDC adding the positive and negative supplies.
Other people tested the original project and got a very high ripple at max voltage and max current because it didn't have enough unregulated voltage to regulate. Its max output voltage with good regulation was lower.
mathiasx
Oct 5, 2006
4
Hi to all, and thx a lot for the information of this proyect
I have a cuestion, Can i use C3851 to replace Q1 & Q2? and D1691?
audioguru2
Apr 6, 2004
12,022
A Japanese 2SC3851 is identical to a TIP31A.
Sorry, I couldn't find spec's for a D1691.
audioguru2
Apr 6, 2004
12,022
Yes, a Japanese D1691 is also fine when used as Q1 and Q2 in this project, if its pins are connected correctly (it has a different pinout) and it has a heatsink for Q2.
There must be hundreds of transistor numbers in the world that will also work fine.
mathiasx
Oct 5, 2006
4
I have one doubts, in the scheme the Collector of Q2 ie connected to R13, but in the file of the PCB no.
As I must take like correct?
audioguru2
Apr 6, 2004
12,022
The schematic is correct. The parts layout shows the pins of the original 2N2219 transistor for Q2. You must also look at how the original Q1 has its pins.
Herman the German
Sep 1, 2006
179
To whom it may concern,
I have studied this power supply a bit and found some discrepancies. I can not go along saying that an electronlytic of 3300UF is sufficient for an AC-ripple of 0.01%. 0.1% comes closer according to my experience.
I also have made some changes, e.g. the driver for the power transistor.
Look it up let's discuss.
HtG
comments.doc.zip
  • comments.doc.zip
MP1
Dec 7, 2003
3,397
Hello Herman,
You will not be able to have a direct conversation with the author of this circuit. The original author is "Smart Kits", but it is a very old kit design and lacks modern principals and newer chips that were offered after the initial design. There are new chips on the market that would do the job much better. However, the point of this area is to discuss what is already here. This thread deals with questions to build this project and questions and answers anyone has regarding it.
Audioguru has suggested a lot of changes, so you might mention which version you are suggesting additional changes. Note that "Smart Kits" are not real elaborate designs. They are simple kits to help beginners learn something about electronics. This thread has turned into a major re-design fiasco instead of simple questions and answers for those who are trying to make the kit. I would have prefferred that those who wanted to discuss a re-design would have taken this subject out of "Projects Q/A" and made a topic in the appropriate area. This approach would have been more beneficial to other members. If I ever see myself having lots of spare time, I might move posts around so that it is more organized in this way. I get lots of emails and PMs grumbling about how this topic is no longer helpful to one trying to build the project and that it is much too long to read through. Perhaps we should open a new forum named "re-design"  ;D  (That was a joke, AG)
MP
audioguru2
Apr 6, 2004
12,022
Herman the German said:
I can not go along saying that an electrolytic of 3300UF is sufficient for an AC-ripple of 0.01%. 0.1% comes closer according to my experience. So I changed C1 to be C1, C1a and C1b with a total capacity of 6600µF.
Hi Herman,
I didn't re-design this project, I just fixed its errors that members complained about.
In addition to the 2N3055, 2N2219 and main rectifier diodes "going up in flames", the opamps with a supply voltage higher than their max ratings and a transformer voltage too low, I have recommended using 12,000uF for C1 so that the bottom voltage of the ripple is high enough at full load.
By the way, is R1 just meant to increase the electric bill? It's just unnecessary!
Hee, hee. ;D I agree.
Using 1N4148 as rectifier diodes for D5 and D6 at peak voltages of 33.9401V they certainly will die soon.
I replaced them by 1N4001.
D5 and D6 have R2 limiting their current and the voltage is much lower than the rating for a little 1N4148. 1N4001 rectifier diodes are also fine.
And finally there is a question concerning life time of semiconductors: How many 2N2219 have you already seen to go up in flames?
The best approach for a combination of a 2N3055 is always using a BD139. They match 100% concerning base current of the 2N3055 and emitter current of the BD139.
The small 2N2219 is in a metal case that doesn't burn but many people said theirs smoked then died. It can't dissipate the heat when the gain of the 2N3055 output transistor is low. I recommended the American TIP31A but a European BD139 is the same.
Here is just a suggestion to you. Why don't you use MOSFETs or TOPFETs (Philips semiconductors)? They have a great advantage over "normal" transistors.
This project works fine with common and cheap 2N3055 output transistors.
Using Mosfets would be a complete re-design. N-channel Mosfets would need a voltage stepup circuit for the gate voltage and P-channel Mosfets have gain and would cause U2 to oscillate without additional frequency compensation.
Two 2N3055 transistors work fine.
Have a look at the layout I made.
Sorry. You zipped a Word-DOC instead of replying and attaching the pics. My pc doesn't do Word properly so I can't see them.
lennartt
Nov 2, 2006
3
Last week I discoverd this site and was really enthousiastic about building this power supply.
But now, I tested it, and it seems to work half, because the Output Voltage is always zero and the Current Limitter LED is always on.
Are there any tricks to see where it went wrong??
does somebody have a clear photo of its schematic, im afraid i connected the ICs in the wrong way (although they're connected like in the schematic, on the photo
it seems to be connected otherwise then in the schematic)
PLEASE, help me!
greets from Holland
audioguru2
Apr 6, 2004
12,022
Hi Len,
Welcome to our forum. ;D
The schematic in the project is very clear, when you click on it to increase the resolution. It shows where each pin on each IC connects to.
If you mixed up some of the pins then maybe the IC is destroyed.
Did you substitute any parts?
We can help you troubleshoot it if you can give us some voltage measurements of the ICs.
Attach the negative voltmeter lead to the circuit's 0V output labelled "4" on the schematic.
Turn on the power and turn the voltage and current pots to max. Do not load the project.
List the voltage readings on each pin of each IC and post them. Note that pin 4 of U2 and U3 should have a negative voltage.
lennartt
Nov 2, 2006
3
thanks audioguru,
but I noticed something REALLY BAD!!!
When I bought my transformer (230 -> 2X 24V@2A)
I asked the guy how to connect it, and i did it like he said... how stupid of me... the whole circuit got under a 48 Volts!!!!
No strange things happened actually (no smoke, no "PLOOFF").
when I turn the device on now, the Led only burns when the current limiter potensiometer is turned completely to the right.
you thing its still necessary to measure the IC's (which were always good connected and i have no components replaced (except the 200pF is 220pF))?
audioguru2
Apr 6, 2004
12,022
If you connected 48VAC to the circuit then the positive unregulated supply would have been about 69.3VDC, plus the negative 5.6VDC so two of the opamps would have been powered with 74.9VDC. The TL081 opamps have an absolute max voltage rating of only 36VDC.
Since the current adjustment pot works, but only when the pot is turned to max then the pot might be wired backwards.
Maybe the voltage adjustment pot is also wired backwards, resulting in 0V output when it is turned to max.
The circuit doesn't have a 200pF capacitor. C5 is listed as 200nF but a 220nF (0.022uF)capacitor is a standard value. It is 1000 times the value of a 220pF capacitor.
Manda
Nov 5, 2006
Hello!
Before all, please forgive me, my english is not so good...  :(
My problem: I think about to build a PIC controlled power supply, but i'm not so good at the analog part, not able to design my own power supply, so i like to make from this. My question is that what high current and voltage on the control potmeters? can i use digipots there? Because many of them has very small current and voltage limits. I only find digipots from Microchip (MCP40xx, MCP41xxx)
Please help
Manda
Quattor1
Nov 10, 2003
Hi ya all,
I'm thinking of building descrete OP amplifier instead of TL081 for two main reasons. Firs of all, that way I'll be quite OK with votages for up to 60 volts (with this version) and secondly, it'll cost me even less than suggested higher voltage replacement OP amp.
OP amp is going to be Bryston DOA33 or DOA68 - 8 transistors and few resistors... If it's good for Bryston audio amps I'm quite sure it's going to be quite all right in here.
Regards!
