100 KHz tuning fork crystal oscillator
Andrew Holme
I want to build a phase-lockable VCXO using one of these tiny 100 KHz tuning
fork (cylinder-type) crystals:
http://www.citizencrystal.com/images/pdf/k-cfs.pdf
I've got it to oscillate using the classic unbuffered CMOS inverter circuit
with a 5V supply, two 33pF loading caps, 1M feedback resistor and 100k
current-limiting resistor. This may still be too much drive - the datasheet
says 1uW max.
Is this a suitable circuit for these crystals? Can anyone recommend a
better circuit?
TIA
Mark
Check the input side of the inverter with a hi-Z 'scope probe.  If
it's significantly less than rail-to-rail and looks sinusoidal you
should be OK.
that was the easy part..
now how are you going to make it voltage controlled?
Mark
Joerg
'tis why varicap diodes were invented. But you'll have to use another
inverter (preferably a Schmitt) and some discretes to provide 15V or so.
