Hi Zak,
You can't bridge two of these amps without blowing them up.
A bridged amp must handle twice as much current as a single amp, for the same speaker's impedance.
It is easy to calculate the approximate power out of an amplifier.
Yours has an 80V supply. Its darlington output transistors and emitter resistors will create a loss of about 5V each when loaded. Therefore the max sine-wave signal is 70Vp-p.
70Vp-p is divided by 2.828 (twice the root of 2) to get its RMS voltage of 24.75V. Then 24.75V squared divided by the speaker's impedance (probably 8 ohms) equals 76.6W RMS.
It "peak power" or sometimes called "maximum power" is double which is 153W. Its "music power" is any made-up number like 1kW.
