12 V DC to a 220V AC Inverter AMplfier Design
audioguru2
Apr 6, 2004
12,026
kachew said:
then the 2 capacitors to be used is metalized plastic type? since there are no 0.22uF capacitors in the circuit.
The 220K is 220,000pF which is 220nF or 0.22uF.
so 50Hz of frequency doesnt neccessary to put the resistor in front of the mosfet? since the osc frequency in this circuit is just 50Hz.
No. A Mosfet oscillates at a very high frequency if it doesn't have a resistor in series with its gate. It will overheat if you allow it to oscillate at a very high frequency.
the capacitors and resistors used in the circuit is just a protection from the current of the transformer or just use for filtering purposes?
The value of the capacitor is too low and the value of the resistor is too high to make a filter. They reduce high voltage spikes a little.
kachew
Jul 2, 2006
104
dear au,
i have use the same connection which the updated by you...but still no avail, but i tried the cd4047 output from both pin 11, and and 10 and the output is inverted...but when fed into the CD4001...the output seems to be havin a square wave....how could this possible ? i still cant figure it what is wrong with the circuit....mayb is the frequency prob? and i also have taken out the resistor since is not needed.....and can i use the ceramic capacitor which has value of 221k?
thanks for your reply
audioguru2
Apr 6, 2004
12,026
Hi Kachew,
A ceramic capacitor or a "green cap" is marked with the value coded;
220= 22pF, 0.022nF
221= 220pF, 0.22nF, 0.00022uf
222= 2200pF, 2.2nF, 0.0022uF
223= 22nF, 0.022uF
224= 220n, 0.22uF
225= 2.2uF
I attach a logic timing diagram for your CD4047 and CD4001:
kachew
Jul 2, 2006
104
dear Au,
if the voltage from the mosfet is lower than the primary winding of the transformer for example....the voltage from the mosfet is approximately 5V then the rating of the transformer is 8V....will it have enough power to power the transformer? or it depends on the rating of the mosfet?
can i put different grounding where the mosfets have different ground than ground together with the ic? becoz i afraid that the high current drain from the mosfet will affect the ic and burn it.... :-\ :-\
thanks for your precious opinion
audioguru2
Apr 6, 2004
12,026
The Mosfet is just a switch. It doesn't have voltage, the transformer has the voltage and the Mosfet shorts it to ground when it turns on.
The pcb traces should be planned so that the very high current through the ground path from the Mosfets doesn't affect the ICs.
kachew
Jul 2, 2006
104
dear au,
do i still need to add on the series resistor to the mosfet? or shouldnt i?
thanks...if yes then i need to drill holes on my pcb board go lab to retry
thanks
audioguru2
Apr 6, 2004
12,026
kachew said:
dear au,
thanks
As I said before, the gate of a Mosfet needs to have a resistor in series to stop it from oscillating at a very high frequency which wastes power and makes it get hot. 47 ohms or 100 ohms is fine.
Your schematic showed 1k resistors but 47 ohms or 100 ohms will make them switch quicker.
kachew
Jul 2, 2006
104
dear au,
about the grounding...can i separate the grounding as showed in the schematic.... i mean the mosfets has its own grounding and the ic's has it own groundin....or both mosfet and ic need to hav same grounding...i means is connected to same  ground...just wan to confirm b4 i burns everything out... ;D ;D
audioguru2
Apr 6, 2004
12,026
kachew said:
about the grounding...can i separate the grounding as showed in the schematic.... i mean the mosfets has its own grounding and the ic's has it own grounding.
Have heavy wires from the Mosfets to the battery connection, then separate wires from the pcb where the ICs are to the battery connection. Then the Mosfets have separate wires for their high current and the ICs also have separate wires for their low current.
kachew
Jul 2, 2006
104
dear au,
yes i have separated the ic wires to the battery connection and the heavy wires from mosfet to the ground and the to battery....but the problem is the ic need to be connected to the mosfet which acts as a wave generator to switch on and off for the mosfet....then ground of the mosfet also separated from the ic ground but the drain of the mosfet are using pcb to heavy wires then to transformer... i will take attach the pic along for you to see.....and 1 more prob which could not be solved...whcih the the waveform....i still cant get the desired waveform from cd 4001 and cd 4047....
i tried the cd 4047 output pin osc, pin Q and pin Q' all is the same in the datasheet...bt when connected to the cd 4001 it will become a square wave....which each of the output from the cd 4001 will have a phase different only not inverted waveform....when add together it will superimpose but not generating modified sine wave..... :'( :'( :'( at 1st, can generated the desired current and voltage but after awhile it will burn the CD4047 ic ...need help thanks
kachew
Jul 2, 2006
104
dear au,
ooo can u recommend me a voltage regulator? regulate to the ic.....so that the ic will be protected from being burn....thanks
audioguru2
Apr 6, 2004
12,026
The output of each CD4001 NOR gate is supposed to go high for 1/4 of the time and alternate like this:
kachew
Jul 2, 2006
104
dear AU , yup i know...but the osc result doesnt have the required result....i tried many times....at last i will get the same square wave form....but this is ok... the main things is the ic burn many times....although i have use diff grounding and bigger size wire....can u recommend me a regulator which suit to the ic? i think this is the most efficient way....can i voltage regulator to regulate current? as i know regulator is to regulate voltage only
audioguru2
Apr 6, 2004
12,026
Hi Kachew,
Which IC is burning?
What is the DC supply voltage?
If the supply is from a car then it has many voltage spikes. Connect a 16V 5% 1W zener diode and a 0.1uF ceramic disc capacitor across the supply pins of the ICs and feed the positive supply voltage through a series 47 ohms resistor to them. The positive supply voltage can be connected directly to the transformer's center-tap.
Connect 100 ohm resistors in series with the gate of each Mosfet.
kachew
Jul 2, 2006
104
hi au,
the CD 4047 ic is burning at 1st it can be used for generating pulse but later when i turn off the power supply from the lab...it seems burn and i use OSC to check the waveform and there is only noise no longer have any square wave in it...the DC supply in is 12 volt but after i connected to the inverter circuit and transformer for amplification the reading on the power supply drop to 5V and the current goes high...
is this is the modification u meant?
audioguru2
Apr 6, 2004
12,026
You disconnected the ICs from the positive power. You are supposed to connect a 47 ohm resistor from the positive power to the ICs in series, then connect a zener diode and capacitor across the ICs.
An inverter is supposed to be powered by a big car battery, not a lab power supply that doesn't have enough power.
audioguru2
Apr 6, 2004
12,026
The 0.1uf ceramic disc capacitor is missing from your schematic.
The zener diode and the 0.1uF capacitor are across the power supply pins of the ICs.
kachew
Jul 2, 2006
104
Dear Au,
the ceramic disc capacitor is still there....which is parallel with the zener diode ;D ;D
audioguru2
Apr 6, 2004
12,026
You changed where the zener diode and ceramic capacitor are connected. They should be connected directly across the supply pins if the ICs. Now you have them connected across the high current 12V instead which is wrong.
