12 V DC to a 220V AC Inverter AMplfier Design
audioguru2
Apr 6, 2004
12,026
Your inverter will be about 80% efficient. So 150W to the load and 38W of heating. Get a transformer rated for 188VA or its amps is 188/12= 15.7A. The higher peak current in the Mosfets is only momentary.
kachew
Jul 2, 2006
104
dear au,
i found from one of the inverter side and they given some formula which they have different calculations from you which is:
1) to convert amps to watt:
multiply: amps*220(ac voltage)= watts
which is my amps for the transformer will be approximately become 0.68amps
for example, u have a freezer with a continous load of 4amps and start load of 12 amps:
4amps multiply 120volts=480watts continous
12amps multiply 120volts =1440 watts starting load
after i calculate this result is very different from your result...can u explain the different between this.....
as i know 15.7Amps transformer is very bulky and expensive....my motive is to make simple and check msw inverter....
can u help me on this?? thanks alots.... your help is highly appreaciated
audioguru2
Apr 6, 2004
12,026
You cannot buy a transformer that is 8.5V-0V-8.5V to 220V. You buy one that is 220V to 8.5V-0V-8.5V instead. For it to pass 188W continuously then its 8.5V winding must pass 15.7A continuously. The current rating for its high voltage winding is not mentioned.
188W is a lot of power. If you use a tiny and cheap 220V to 8.5V-0V-8.5v/0.68A transformer then the continuous power output from the inverter is only 6.5W and you could use a very small battery.
kachew
Jul 2, 2006
104
dear au,
what u mean by this? i cant understand....last time u called me to buy a step up transformer...now u said i need a step down transformer???
audioguru2
Apr 6, 2004
12,026
Nobody makes a step-up transformer. Buy an ordinary step-down transformer and connect it backwards.
Don't think of current, think of power. Then calculate the current.
kachew
Jul 2, 2006
104
dear au,
can this step down transformer works? my friend had tried this method and it seems doesnt works.... i have ask the shopkeeper here...they said can make a step up transformer for which is custom made...
i need the power of 150watts...
now i become more confuse on the amps needed for me to choose the right transformer ??? :'( :'( ???
audioguru2
Apr 6, 2004
12,026
150W output plus 38W of heat in the inverter circuit = 188W total.
188W/12V= 15.7A from the 12V battery, into the low voltage winding of the transformer and is the average current in the Mosfets.
15.7A is the average continuous current, the peak momentary current is higher.
If you overload the transformer or the Mosfets then they will overheat and fail.
micro_guy
Apr 2, 2007
well i think it isnt possible or if it is possible then the sytem will be unstable
audioguru2
Apr 6, 2004
12,026
These are switching inverters that do not have a linear amplifier. They don't have negative feedback. They switch 12VAC at a very high current into the low voltage winding of a transformer and the transformer steps-up the voltage.
They work fine and are not unstable.
kachew
Jul 2, 2006
104
hi Au,
Quote
The Mosfets are turned off for half of the time so their current must be doubled for the inverter to produce the same average output power as a square-wave inverter.
the IRF 540 mosfet only can withstand 23A only, then i need 3 mosfet on each side to withstand that large current or just simply 1 mosfet at each side cos 150W divided 12=15.7A???
audioguru2
Apr 6, 2004
12,026
Hi Kachew,
If your inverter will have a max load of 150W then its total power including heating is 188W. The average current from the 12V battery is 188/12= 15.7A but the peak current is 2-root-2 times= 44.4A because it has a modified sine-wave with pauses.
The IRF540 Mosfet is pretty old and has a fairly low max current rating. It is 23A continuous if its case is at 100 degrees C and is a little more if it is cooler. Two of them on each side would be very close to their limit so use 3 on each side.
audioguru2
Apr 6, 2004
12,026
kachew said:
hi Au,
can u recommen any better mosfet? thanks
I don't use high current Mosfets. The online catalogs of Digikey and Newark have hundreds of them. Some can conduct over 100A. I don't know what you can buy.
kachew
Jul 2, 2006
104
hi au,
can u pls gimme the link? i go and find myself :p thanks cos i need to create the inverter as small as i can
audioguru2
Apr 6, 2004
12,026
www.digikey.com They are in some countries.
www.farnell.com and click on the flag of your country.
I look at Canadian and United States pages.
kachew
Jul 2, 2006
104
dear au,
i think i can use this mosfet rite?
IRFZ48NPbF
i will attach the datasheet for your reference....thanks
audioguru2
Apr 6, 2004
12,026
Use two of those Mosfets on each side for a 150W modified sine-wave inverter.
kachew
Jul 2, 2006
104
dear Au,
on what gound u state that i shold use the 8.5-0-8.5 to 220V to get the Vpeak for the output of the transformer? as i know output of the transformer is Vrms?
u stated that in order to get Vpeak at the output , the value for the inverter the input of the transformer winding is calculated as 12/8.5 which is nearly square root 2...do u have any site or article to prove this?
the vpeak at the output transfomer become Vpeak as sine wave if i use the 8.5-0-8.5V to 220V transformer? do u have any nice article about transformer?
do u have any site or article on this? so i can understand more...because i dont know which formula you are using to calculate the current in mosfet....which is peak current is 2-root-2 times 15.7A=44.4A because there is pauses between the mosfet .  as i know Ipeak =square root 2 multiply by Vrms.....by there is extra 2 in front?
my theory on inverter is very limited hope you can giv me more information about it thanks
kachew
Jul 2, 2006
104
dear Au ,
i think i get what u mean if this is correct,
the input and output of the transfomer is calculated using Vrms or so call average value?
so in order to get the Vrms in the transfomer we need to 12V/square root 2 = 8.5V in the primary winding of the transfomer? so we can get the output of the transformer Vpeak value as 220Vac peak straight? or the output of the transformer still need to multiply by square root 2 since the output of the transformer is just the Vrms value not Vpeak?
for the current part in the mosfet.....what u means is the mosfet in the inverter on each side is 15.7A drain from the battery so with the modified sine wave because of the mosfet turned off half of the time we need to double the current in the mosfet in order to get the average output power which is 150w continuos
so the formula given to me which is 2 root 2 times 15.7A where the 2 in front is to double the current in the mosfet in order to get same avg output power....is this correct?
but how we know by doing this we can get the same average output? can u explain more and also  why their current need to be double to produce same avg output power for the turn  off for half of  time in the mosfet ....
but i also need some article for my above question which i need to prove it in my thesis.....so my thesis is more solid...
thanks Au
audioguru2
Apr 6, 2004
12,026
Hi Kachew,
1) A square-wave inverter has the 12V from the battery switching back and forth in the primary of the transformer. The battery current is nearly continuous and is steady. Its output voltage has a peak value the same as its average value which is the same as the RMS voltage if it is a sine-wave.
2) A sine-wave inverter has the 12V from the battery stepped up to an RMS voltage. Its peak voltage is 1.414 times higher (root 2).
3) A modified sine-wave inverter switches the primary of the transformer on for one side then off, then switches on the other side of the transformer then off. Its current is turned off for half the time so its peak current must be doubled to achieve its rated RMS power output.
Its peak voltage must be about 1.414 times the RMS voltage.
The sine-wave inverter and modified sine-wave inverter must use a transformer with a higher step-up ratio than a square-wav inverter. The ratio of 12V to 8.5V= 1.412 which is close enough to the desired 1.414 (root 2).
I saw articles in Google for modified sine-wave inverters. I didn't save the articles but instead I saved this pic of the waveforms in 120VAC inverters:
