2.4v NICAD CHARGER?
polyal
Sep 8, 2011
24
Q for the geeks
I need to build a charger for a 2 cell electric screwdriver (2.4v)
i found this circuit on utube will it work . . .thanks
edit : op amp powered via pin 8/4( not shown )
polyal
Sep 8, 2011
24
b&d 9018
i just need a generic charger and wondered if this circuit is valid
the original charger is a wall wart 5v ac supply with an inline diode . .
how good is that ♪♪:)
14,487
b&d 9018
still a little info lacking ...
we dont know the type of battery(ies) in that B&B unit --- do you ?
we dont know the type of battery charger cct that circuit is for --- do you ?
polyal
Sep 8, 2011
24
i just need to charge 2 nicad batteries ( 1.2v C size ) which will be pemanently
installed in this screwdriver ( the original batteries have long been discarded )
is the supplied circuit suitable for charging 2/ B type nicad batteries in series
. . my main queerie is . . . is this circuit valid . . will it work ?
thanks
One can knockup a basic nicad charger using an lm317 ,a pot a 12v plug pack and use multimeter to set the current.
Advantage charge any number of nicads up to 8.
Search Google for lm317 nicad charger.
14,317
Your schematic is flawed. The pinout of the opamp is wrong:
ramussons
Jun 10, 2014
475
There is a flaw in your schematic. How is the lower BC547 supposed to function?
crutschow
May 7, 2021
991
Below is a CC-CV charger using the common LM317 regulator and TLV431 programmable voltage reference:
It charges the batteries at 210 mA constant-current and limits the charge voltage to 3V.
The TLV431 limits the voltage when the Vref voltage from the R1/R3 divider reaches 1.24V.
