N
Nico Coesel
- Jan 1, 1970
- 0
Every now and then I spend some time tinkering with HF stuff.
I've put a board together with an ADF4350 fractional-N PLL chip to
serve as a simple RF generator. The ADF4350 can output a signal
between 140MHz to 4.4GHz. It seems to work but the output shows a
large dip at 2.487 GHz and small one at 2.287 GHz (see
http://img201.imageshack.us/img201/4512/img0498ry.jpg showing 2
traces). I can't test beyond 2.6GHz
The board is a 4 layer FR4
PCB.
So far I tried to change the decoupling capacitors (0402), add extra
wires to the power supply pins, change the output termination, use
different cables (SMA) but this changes nothing at all.
Is there an easy way to pin this problem down without spending another
fortune on equipment? I guess there is a parallel resonator somewhere.
To make matters worse I'm not quite sure my SA is 100%. I'm thinking
about simulating the board using Sonnet or putting together a simple
power level meter.
Any other ideas?
PCB.
power level meter.
Any other ideas?
