200 AA Batteries to make a portable power supply
LionHearted
Dec 30, 2014
3
Got some music equipment I wanna busk with but theres no battery slot... So I was just curious, can't I just get 200 1.2v batteries then get a wall socket to plug it in?
Might be a bit simple minded but I'm curious.
14,486
hi
welcome
wall power outlets are AC
Batteries are DC
see the difference ;) :)
LionHearted
Dec 30, 2014
3
Probably another bad question, is there a formula I can use to determine how long the batteries will last if I know the wattage, voltage and amps that are going to be drawn?
14,486
for rechargeable batteries, that's reasonably straightforward as they have their amphour rating on them
so say its a 2000mAHr battery that means at best you can draw 2 amps for 1 hour
in practice/reality it will be a bit less than that because of battery voltage drop and other factors
Look into deep cycle sealed lead acid batteries. These will have an amp hour rating. Since they are 12V, you multiply by 12 to get a Watt Hour rating. For example, a 35AH battery is 420 Watt Hours. If you music system uses 50W this would last about 8 hours ideally. But an inverter is going to be no more than 90% efficient, so maybe 7 hours. And furthermore, the ratings of this type of battery are for discharge over 20 hours. Faster discharge rates will reduce the available energy, so maybe 4 hours. If the music system required 100W it would be more like 2 hours.
