24v auto relay changeover ???
davit
Aug 16, 2017
39
hi
need help please i have a 24v 9 40amps) marine electric outboard engine, contolled by multi position switch,
5 forward / netural / 3 reverse positions, the thing is i need to run another motor of the same switch,
just to double up wiring would result in burning out the swich contacts, i know how wire up a relay to take away the load for the second motor for say forward switch postions, but for reverse the polartiy
changes, so it acts as a brake, initially is this posible using one relay, hope this makes sense ish
many thanks
david
Kabelsalat
Jul 5, 2011
198
You need to make out the following yourself:
  • Wiring diagram
  • Set up a complete map with the connection between each wiring terminal against the others.
See the attachment how to make such a connection diagram.
14,317
To help you with the diagram:
Kontaktdiagram = contact diagram
Hauptkontakt = main contact
AUS = off
EIN = on
Hilfskontakte = auxiliary contacts
Startpos. = starting position
Endpos. = final position
Isolationsdistanz = isolation distance
davit
Aug 16, 2017
39
thanks for the replys will try to draw out a diagram
thanks
