24v Keypad - Microcontroller
Sadlercomfort
Ash
Feb 9, 2013
424
Hi guys,
Does anyone know how to interface a 24v keypad to a microcontroller.
Usually I would use a 5v keypad and connect it directly to one of the ports with pull up resistors. However I can only find a 24v one for cheap on farnell so I have to use this.
http://www.farnell.com/datasheets/1804053.pdf
Is this a 24v max rating? Or do i need to use 24v?
Ash
Minder
Apr 24, 2015
3,561
Those KB's are passive devices, just tactile switch so 5v or 24v does not really matter, they are set up with a matrix to save on I/O, see the tutor series by Nigel Goodwin Tutorial site.
M.
Minder
Apr 24, 2015
3,561
As long as you observe the 50ma rating.
Correction, I see they have a ilumination LED they mention 5v for these?
Separate connections.
M.
Minder
Apr 24, 2015
3,561
To follow up it appears that the keyswitches are anything up to 24vdc rated, the diode anode/cathode is 5v, I am assuming that there is internal series resistors, it does not mention the inner connections.
M.
