3-Axis Stepper Controller
alberto2
Aug 1, 2003
30
how connect the 3-axis stepper controller (cw technology) to pc? i don't understand the
istructions.. please.....help me!!! :(
Project link: http://www.electronics-lab.com/projects/pc/008/index.html
Alan9342
Hello all.
I have completed the PCB for the 3-Axis stepper controller by CW Technologies and I am about ready to populate the board. However, I noticed on the PCB overlay there are six locations marked "JP1" thru "JP6". Are these jumpers? There is no documentation in the project file or the parts list for these call-outs.
Also, I have tried unsuccessfuly to contact CW Technology about this question.
Any help is greatly appreciated!
Alan
mixos1
Administrator
Jul 13, 2003
581
The through is that the documentation is not clear. First you must not confused by the schematic. The schematic only saw the one of the three controllers that the pcb includes (UCN5804B).With the same way the other two are connected.
So the x=6, y=7, z=8 means that for U1 that controls x motor you connect the pin14 to the 6 of the parallel port. For the U2 that controls y motor you connect the pin14 to the 7 of the parallel port e.t.c. The same you must do for the x=2, y=3, z=4. Did you get the logic of it?
But if you build it with the pcb the things are easier. The only thing you have to do is to connect the numbers that you can see on the pcb overlay to the same numbers of the parallel port connector.
mixos1
Administrator
Jul 13, 2003
581
Yes these are jumpers. They are used to define the mode that each stepper motor works. The modes are: two-phase, one-phase, half-step, step-inhibit. You can see how to set by reading this table:
L means Low
H means High
If you put the jumper then its Low (it short circuit the pin with ground) otherwise is High. So for each motor use the above table to set the modes.
J1 changes the pin9 state and J2 the pin10 state of U1
J4 changes the pin9 state and J3 the pin10 state of U2
J6 changes the pin9 state and J5 the pin10 state of U3
You can read the datasheet for more info on the UCN5804B
Also check the manufacture's site
alberto2
Aug 1, 2003
30
mike thanks! but I still have some questions!
-what is the tension to be applied on the Pin +- Pwr?
-how connect Limit pin?
-x-y-z home?
seen that many people have found problems with the wiring of the circuit, drawing a detailed scheme and putting it at disposal of everybody on the site would be better.
alberto
Alan9342
Has anyone out there built/used one of the CW Technology stepper controllers?
Any input as to ease of setup/use?
How about types of software.
I have read in the circuit documentation that it was designed to use dancad. Has anyone attempted to use another program such as K-CAM?
mixos1
Administrator
Jul 13, 2003
581
The input voltage can be anything from 8V to 35V, but keep it at the voltage that the motor uses and not below 8V.
As saws the schematic. You take a switch and connect the one pin of it to the ground. The other pin to the pin 10 of the parallel port and from that pin with a resistor to +5V that exist at the output pin3 of MC7805. By the way there is a place on the pcb for that switch.
For home switches you follow the same practice. Also check this artwork to see how to connect it to pcb.
alberto2
Aug 1, 2003
30
dear alan i think that you can find more cnc free software in:
http://majosoft.tripod.com/hobbycnclinks/body_hobbycnclinks.html
The 3-axis stepper controller can read other cnc software than dancad.
In the archive software i had found "jalaCNC" and i think is a very simple and intuitive software in windows but i aven't try it yet.
alberto2
Aug 1, 2003
30
Someone has never tried to build a digital Display to show the value of the Cordinate x-y-z, to be applied to panel on the case where to accomodate the 3-Axis Stepper Controller? ;D
Alan9342
Thanks for the reply Alberto.
Ok, I have built the board (cw tech.) and have it connected to my pc.
Before I attempt to power the thing up with steppers attached, are there supposed to be any "power resistors" in line with the motors? Since I cannot find any further information on this stepper controller board I am at a loss with regards to the output of the thing.
I have the entire setup sitting on my lab bench and am using a HP triple output power supply for the testing.
The stepper motors are NEMA 23's 6 wire 5.2v/phase and 1.4a/phase.
Any concerns, comments, or warnings?!?!?
Alan
alberto2
Aug 1, 2003
30
wich software to use with the 3-axis stepper controller?
i'don't like dancad.
Alan9342
Alberto,
I was going to use KCam, however, I have found what everyone was telling me about windows based software is true-it's "choppy". The program did run my stepper controller setup though.
So I tried to use Turbocnc. Could not get it to talk to the controller board or move the motors at all.
I then tried Dancad. The only thing I can get out of it is my parallel port 10 pin is in a high state and then the program locks up. I have searched for a method to put it in a low state (shorting to ground ect.) but nothing works.
I really don't know where to go from here. Any suggestions? ???
alberto2
Aug 1, 2003
30
can i use the 3-axis stepper controller with the serial port of my computer if i use parallel to serial port converter? ;D
EDY2
Jul 14, 2003
85
Hi. I have a EM-236 and EM-237 bipolar stepper motors that I would like to hook up with this project. However they need 36V power thus I can't use 5804 controler. What would be aduequate replacment? Oh and does anyone have datasheet for these two motors?
Thanx
EDY2
Jul 14, 2003
85
Nevermind my previous post. I figuerd that those motors only have 2 steps so they would be use less
alheira1
Oct 11, 2003
How many people have a 3-Axis Stepper Controller project working?
Each one who does please:
How fine the project works?
And what about the software?
What kind of hobby work or aplication?
cncmadman1
Sep 12, 2003
3
Worked for me. No problems whatsoever
Works excellent
TurboCNC (which reminds I need to send that guy 20 bucks)
PCB milling and drilling, Wood carving, Aluminum RC car parts just whatever I feel up to
jjwl891
Dec 6, 2003
4
can i only use 6 wire motors or are 4 wire motors compatible too?
also digi-key has discontinued the 0.01uF 63v monolithic capacitor (P4914-ND) and the slide on sink for U2 (HS125-ND
