3-Axis Stepper Controller
MP1
Dec 7, 2003
3,399
Did you over heat the UCN chip? You probably need to build one of the other designs if this is the case.
MP
nikolaw
Aug 30, 2006
32
MP
how do u men i over heat the UCN chip?
MP1
Dec 7, 2003
3,399
The chip does not have a high watt rating. If you are using steppers that consume large amounts of energy, you could damage the chip.
What is the rating of your steppers? What is the rating of the power supply you used?
MP
nikolaw
Aug 30, 2006
32
MP
I have a problem
I build another Bord but one chip broke again i use http://www.doc.ic.ac.uk/~ih/doc/stepper/others/example2/
and PC power supply
What is the problem  ??? ??? ??? :'( :'( :'( :'(
How much Volts and Amperes i mast to use ???????
PLEASE HELP ME
MP1
Dec 7, 2003
3,399
Nickolaw,
What are the symptoms of the fault? When you say it is not working, what is it doing? Have you checked the power supply? Has something burned on the board? If not, have you checked all settings in the software? Have you slowed down the steps to make sure the motor is not stalled? Have you checked the pulses coming from the board? If you use a slow stepper setting, you can use LEDs to check the stepping sequences. This is a useful tool as long as you step the motors slow enough to see the individual steps with the LEDs. Don't forget to add resistors so that you do not burn out the LEDs.
MP
nikolaw
Aug 30, 2006
32
MP said:
Nickolaw,
MP
All is ok on board only one UCN5804 broke down and i replace that UCN whit another and everything i s ok bat what can burned UCN's i Use power pc suplly is this big supply?
should i use
1. small power supply (i mean in A and V)
2. or use fuse
3.how mach is max volts and amperes of power supply what I can use for this board
MP1
Dec 7, 2003
3,399
The questions I posted are key questions to try and determine where the fault might be. Without answers to them, I really do not have a clue as to what is wrong.
The pc power supply has quite a bit more amperage than what you need, but the power supply does not cause this problem. Something is drawing too much current. The power supply is only obliging with what is requested of it. You should find out what is causing the excessive current draw. My guess would be that you have designed a stepper board that requires more current than the UCN chip is capable of running through it. If this is the case, you should scrap the idea and build a controller board that is capable of a few amps or more.
Perhaps you have chosen some wrong components that causes a draw. Can you post a drawing of your board? I tried to determine more from the pictures you posted, but they do not help for diagnostics. Post your board layout and description of parts you have used and we can try to determine if it is a component or too much current draw from the motors, etc.
MP
thotrang
Dec 26, 2006
should i use
2. or use fuse
You can post your schema in here then everyone can help something for your.
Best Rgds,
fever16
Mar 12, 2006
41
hello guys,
its a very good and nice thread for 3-axis cnc.
of course its a long thread of 22 pages (took me 1 whole day to read and understand) but iam able to solve my lot of doubts and questions.
thanks guys (spl. MP,nikolaw and GreekPIC... others too)
i saw lot of questions regarding the PCB layout.i think they arise bcz of the improper design software.the author shld have provided them in eagle etc format so that it will help while making the pcb.i'll be real thankful if some one could do that.(if someone has it already pls do post)
some of my doubts that need clarification:
1.in the below pic is that 5v regulator only?
2.how to connect home limit switches?
  if we use 3 limit switches for home then overall we need 6 switches. right?
3.i have some 5-6 wire stepper motors from old printers.how to know whats their  voltage rating.imean 12v or 24v etc
and has any one used this entire setup roughly?
i just want to know how efficient it is?
once again i want to thank all of u for providing some much info.
dBlaza
Feb 1, 2007
Hello guys and if there-s any girls :)
I'm in "maybe" little problem.
I've made circuit like in example for Optoisolated stepper motor controller.
It looks like this
and I took a stepper motor from the scanner which have this caracteristics
Items M42SP-7
Rated Voltage DC 12V
Working Voltage DC 10.8~13.2V
Rated Current/Phase 259mA 173mA
No. of Phase 4 Phase
Coil DC Resistance   50Ω/phase±7%
Step Angle   7.5º/step
Excitation Method 2-2 Phase excitation (Unipolar driving)
and have 5 wires which are> red, black, brown, yellow and orange
i've readed little bit about wireing of steppers and that the phases(wires) of stepper must be in some strict order
so I tryed and tryed and it doesn't work, everything that i can get out of stepper is that he vibrates or nothing.
ps i have winXPpro and parallel adress is 378 checked in bios and there is something about parallel port (ECC ...)
I'm sorry for my english,
and I hope that someone is going to help me about it
Thanks to all
slikdig
Feb 2, 2007
I've had a hard time finding UCN5804's recently. There either out of stock or exorbently expensive. Any suggestions on where to find them?
timnlenoir
Jul 7, 2005
Try this site out http://www.cncresource.com. I shearched their site and found them for $4.50. I have not ordered from them yet but will in a few days.
Here is the full link.
http://www.cncresource.com/store/index.php?main_page=product_info&manufacturers_id=4&products_id=6&zenid=71c00ef3ea67643309096144674745be
steev
Sep 25, 2005
49
exactly i too had hard time in finding those 5804 chip.
either no availability or too costly for a small CNC project.so i moved for pic based stepper controller(linistepper)
new Kid
Apr 17, 2007
Hi guys,
I am new to this field...and wanted to build cnc for hobby...i read the thread and was facinated by this machine can do...
i'm just wondering if any body have a pcb ready for soldering the parts and how much it is? and please advised for payment method and shipping. ???
I hope this forum still alive :-[
Thank you in advance  ;D
thanks
nikolaw
Aug 30, 2006
32
new Kid said:
Hi guys,
thanks
Where are you from?
GreekPIC
Aug 1, 2004
251
There's a 7805 5V controller onboard. It can take 8-35V as an input (actually whatever voltage the steppers need) and output 5V for the UCN chips
Depending on the software you use, you can use NC or that as the switch being pressed and it will stop. You can spare some parallel port pins by wiring all three limit switches in series. The limit switches are no to be used on purpose like the home switches so you can live with that. If the machine hits a limit, you can visually check which axis it was.
Now, that's hard. Google each and every marking, serial number or brandname you see on them and try to find a datasheet.
Nikolas
nikolaw
Aug 30, 2006
32
Where i can Bay online step motors?
can you tall me some web pages?????
thanks
