3 phase AC output transformer 30 degrees to 120 degrees how?
Danny Daviss
Mar 16, 2013
67
The 3 Phases are 30 degrees apart before the output transformer
The output transformer turns 30 degrees into 120 degrees AC, but how does it do this please?
Its for 3 Phase UPS systems
14,317
What circuit are you talking about?
How do you know these pahse differences? Did you measure them? Where do they come from?
I very much doubt that what you describe really happens. A transformer can rotate the phase from input to output. However, it will do so for all phases in the same way. Therefore, signals that are 30° apart on the input side of the transformer will still be 30° apart on the output side - even if they are 180° phase shifted between input and output.
Danny Daviss
Mar 16, 2013
67
Its a UPS 3 phase system
The phase difference are 30 degrees apart before the output transformer
Yes I understand that too
Danny Daviss
Mar 16, 2013
67
Its 3 phase , 120 AC , 120 degrees is the output of the unit
When you measure with an oscilloscope before the output transformer the 3 phase waveforms on a 3 channel oscilloscope are 30 degrees apart. When measuring the 3 phases after the output transformer, the 3 phase are 120 degrees apart.
How does that work?
