[email protected]
- Jan 1, 1970
- 0
I notice that a lot of fans, including all I have recently bought, have
3 speeds controlled by a switch. So I was wondering how they manage to
control the speed (yeah, I know ... via the position of the switch
Latest one I bought has parts more visible (I don't want to take them
apart). There are 4 wires to the switch. So it would seem likely that
one wire is common and the other 3 are selected by position, and none
are selected for off. There's a 3uf capacitor and what looks like a
shaded-pole winding in the motor itself.
The motor type that seems to fit is "permanent split-capacitor", also
known as "capacitor start and run".
If the starting winding is permanently connected, is there any design
change over that of a switched winding that is needed because it will
be permanently powered? For example would the number of winding turns
need to be greater? Or maybe different capacitor? Or at at different
angle in the stator?
I read that the switch selects taps in the main winding for speed. But
is this just a selection that affects slip, or does it change the way
the winding is slectrically configured? Could more taps allow more steps
in motor speed? Is there a low end limit on the speed that can be set
this way?
I have noticed that it always is the case that the first position next
to the off position is the highest speed position. Is this done because
that is the best for starting the fan from a not-running state?
I tested a couple of fans I have (the circulate air in the computer room
by getting them spinning in the wrong direct by driving the backware with
another face facing into it. Then I flip the switch and notice that the
fan has no trouble getting started by quickly slowing down the rotation
that's going in the wrong direction, to a stop, then going in the right
direction. This works fine even which quickly switched to the slow speed.
My father has a ceiling fan with a pull chain that increments the speed
in steps with 3 speeds possible, and also has a wall switch with 3 speeds.
Turns out there there are more than just 3 speeds possible based on the
combinations of both switches. How does this happen? I have not looked
at the wiring, but I assume there are as many wires as the wall switch
needs to have going between the fan and the wall switch. Could the pull
chain switch be selecting different taps on the other end of the winding?
The ceiling fan has a reverse switch. I'm guessing that simply reverses
the permanent start winding.
this way?
