3v step down from 12v
Crafts4Me
Feb 10, 2022
168
hi
thanks
that was the issue
output was 9.89 i was able to turn the potentiometer to read 3.10 the first flame bulb was burnt out but the rest are amazing.
i learned something.
thanks so much
1- i have the multimeter
2- that there is a potentiometer that can be adjusted
i appreciate all your assitance
is there a good tutorial to learn how ro use the multimeter across all applications?
14,317
Good link by @bertus .
One simple tip to remember:
- voltages are measured in parallel
- currents are measured in series
Martaine2005
May 12, 2015
5,318
One other simple tip:
Using old baking trays are metal and conductive, always use an insulator material too so not to short the solder side of boards.
If you have a cutting board, place it between the baking tray and PCB.
Crafts4Me
Feb 10, 2022
168
hi
now that i added this bulb flame lamp to my project do i have to woory it will get hot over time or once ts been adjusted corectly and reads 3 v it will stay in a safe mode?
Crafts4Me
Feb 10, 2022
168
thank you
project completed perfectlyi appreciate all the help
i am sorry the photo isnt so clear so i cannot attach it
Crafts4Me
Feb 10, 2022
168
14,317
And with respect to your other thread: yes, you can use the module used here also for 5 V with the appropriate setting of the potentiometer.
14,317
Look in your other thread. I described it there.
Sunnysky
Jul 15, 2016
577
TL;DR
Why bother when you can put 4x 3VLEDs in series and repeat as many in parallel as you want and switch on/off from ground with an NPN.
If that isn't enough current or your 12V reg is worse than 2% use 3 in series with a R to drop slightly less than 3V for I=V/R
Or do you need 5V for something else? and that has nothing to do with the LED voltage requirement.
What LEDs are you using (link)? if Vled = 3.1V then 3x3.1 = 9.3 then if 12V is 12.0 the drop is 2.7V/20 mA=135 ohms or nearest higher value.,
Crafts4Me
Feb 10, 2022
168
hi
i added to the same therad once again step down form 12v
my dioramas are all wired for 12v with LEDs etc
i want to add a 5v USB bubbler to the same wiring without needed another plug
