globecollector
- Jun 27, 2011
- 27
- Joined
- Jun 27, 2011
- Messages
- 27
Oh, just another quick comment...you need to provide a PWM signal to this chip to dim the LEDs, so you will need to build a separate PWM circuit...it will need a regulated supply voltage, so use the DC-DC Boost converter for this.
Follow all the design tips for this chip closely...particularly the high frequency, high current paths around the inductor, bypass capacitors and shottky diode...it will work like cpap if you don't and radiate R.F., stirring up every radio and TV for miles around.
Some tips if you do not wish to make a PCB...you will really know how to solder very well...the chip is probably surface mount and really tiny...you will need a magnifier, fine solder, SMD flux if you can get it.
Get a tin can, not aluminium, but tinplate...like a Tuna fish can. Try to get all the polymer coatings and printing off it..or just use the "bum" of the can which should be bare metal on the outside. Use old 60-40 lead solder, the new silver-tin stuff is brittle and hard to work with. Old scissors will cut a small piece from the bum of the can after you have got it with the can opener...one of those that leaves the seam on the can not on the bum/lid!
Careful you don't cut yourself on the sharp edges and blunt them off with a small file after cutting. Hold with bull-nose pliers whilst cutting if you can...cut close to the end of the pliers.
Bend the ground pin of the chip down with needle nose pliers and solder it to the top of the can so it pokes up perpendicular to the surface but the body of the chip is parallel to the surface and as close to it as you can get without the other pins touching it. This will hold the tiny thing in place so you can do the next step.
First the 10uF bypass capacitor from the "in" pin to the tin can...use a ceramic monolithic SMD capacitor with no leads you can easily wreck this off an old motherboard from a PC, lay the chip's "in" pin across the top of the capacitor with the other end of the capacitor on the surface of the tin...so it stands up on its end like a toombstone...if the chip ain't high enough, lengthen the ground pin with a piece of solid core wire or a little rectangle of tin similar in size as the capacitor until it IS high enough. Now you will have the "rail" and "Ground" pins done and they will hold the chip firmly in place. Now put the inductor, (make sure it is the correct sort, right sort of core and big enough to handle the current...not just any old 47uH...again look for images of circuits built with this chip so you can actually see the inductor...probably one of those "cotton reel" types dipped in army green goo, or a small toroid or pot-core.) Solder it between the "in" and "sw" pins with its leads REAL SHORT...no more than 3mm long if you can. Now put the shotty diode...SMD again if you can find one...must be able to withstand a reverse bias voltage of about 50-70v...research this component very carefully..it is important. Don't use any old Shottky from a cabbaged power supply! Solder its anode right to the inductor-"sw" pin node..again as close and tight as you can. Lastly..the output bypass cap, the 0.47uF...again, surface mount, like a toombstone, one end to the tin can the other to the cathode of the shottky...that's it..those are the bits the 1.3MHz circulates through...all the other bits are non-critical and can have longish leads.
Any wires soldered to these bypass cap nodes, those to the battery and LEDs...strain relief them in some way...loop 'em through pairs of holes in the tin or cable tye them down to the tin through pairs of holes...anything to stop them being pulled and breaking the bypass caps in half.
Oh, put a blob of silastic between the inductor and the tin...it damps the magnetstriction vibrations which will break the leads/solder/pins off the chip given enough time.
Good Luck and happy, (but fiddly) building!
