4 out of 5 Burned Sony Data DVD's contains CRC error ?!?
Skybuck Flying
This night I was trying to backup my source code, emails, websites and
information to a DVD.
This time I wanted to make 100% sure that every bit was verified and tested.
Out of 5 DVD's WinRar reported 4 DVD's as bad/corrupted/crc32 errors !
Only one DVD came through 100% perfect as far as I can tell... another DVD
came very close 99.999999% perfect... but still an unexplained and
undetected bit error somewhere... only the DVD copieing program detected
it... I want to be 100% sure so this second one doesn't count.
That's a failure rate of 80% !
I tried the following:
1. Burning at 4 MByte/Sec.
2. Burning at 12 MByte/Sec.
3. Burning at 16 MByte/Sec.
4. Blowing the drive clean a little bit.
5. Lowering the fans on the PC case... this seemed to help a little bit or
maybe it was a fluck of luck... this DVD was 100% ok ?!?
6. Listening on the table to see if under neighbours or cars/trucks driving
by where making noise.
I noticed the IBM/Hitachi Harddisk do make quite some noise/vibrations on
the wooden table.
7. Disconnected internet.
Maybe harddisk/filesystem a little bit fragmented... by the buffers seemed
to remain full... the read buffer in nero remained above 90% full...
The dvd burner (benq) did seem to drop to 23% at occasions.
One dvd had a little bit of crease and had the most errors. (Wrote with
waterpen on it before burning the rest after).
All other dvd's came clean out of the sony cakebox.
I feel lucky and blessed that I at least got one good DVD out of this
experiment and necessary backup.
Let this posting be a warning message to those programmers and other people
out there thinking about using DVD's as backup mediums !
Always verify the DVD... but that's not enough !
One DVD still came through "verified" by the DVD writing program... however
WinRar still reported corruption.
Another explanation could be that some of my RAM chips might be
corrupted/defect... however shouldn't I have noticed that by now ?!?
I also tried extracting the originals on the harddisk... and no bit errors
or crc's error happen there which more or less proves that it's probably not
a memory error... since it would probably use the same ammount of memory and
such.
I am just hoping that one copy remains good fingers crossed... I also had
another copy... at least the rar's where good.. but maybe some of the
software like executables for extraction might be nuked.
(I also have dual layer verbatims on my closest shelfes... didn't try those
yet... since backup data was about 2.7 GB... so saving those for some other
time ;)... these were 4 GB Sony DVD's which I used...)
What's your experience with burning DVD's... anybody out there experiencing
high failure rates ?!?
Maybe with sony dvd's or benq dvd drives ?
(This is 2006 technology ;) :))
Bye,
Skybuck.
Skybuck Flying
Anyway... what I would need for good backup purposes on DVD's is something
better than WinRar.
I need some sort of compression tool, which does do compression... but which
also adds redundancy...
So that it can at least recover from single bit errors ?!? (Maybe even
multiple bit errors ?!?)
Just detecting bit errors like WinRar does is not really enough... since bit
errors seems to happen more often than not.
Does such a "compression/redundancy tool" already exist ?!?
Bye,
Skybuck.
Skybuck Flying
Hmm interesting I came across this website which claims WinRar can add error
correcting codes to archives...
http://hubpages.com/hub/Interesting-aspects-about-Win-Rar-software
As far as I know the wizard doesn't show it... during compression
decisions...
So apperently this is a tool/feature that can be applied to archives after
they are created...
And indeed WinRar does have a "command" called: "protect archive from
damage".
I am going to try this feature out and see how it works out...
And then I am gonna try one last burn and see if it can actually recover
from bit errors ! ;) :)
Later I might "study" the bad burns to see what kind of bit errors
occured... or maybe not since my time is valuable too you know... me don't
have much time to **** around like this ! ;)
Bye,
Skybuck.
Skybuck Flying
This could be a nice feature... since the ammount of compressed data is only
2.7 GB and DVD has room for 4.7 GB...
Though I also believe more data on DVD is more potential for problems...
especially outer rings...
There are multiple rar's which need to be "protected from damage"... so some
rars might move more closer to outer rings which makes it a bit more risky
but ok... maybe the recovery data can recover from that... it's worth a
try...
I do which this tool was a bit more flexible... so that I could protect all
files... not just rar's...
I shall put the remaining files in a rar as well so that they can be
protected as well..
I also wish this tool had some kind of calculator for all files... to
calculate the percentage...
Or even better just specify the "free space" on dvd...
But ok... it doesn't have that and for now it's guess work...
So far my calculation seems to be around 71% of extra records could be
added... assuming Sony didn't lie and 4.7 GB actually means 4.7 GB ;)
For now I will go with 70% to be on the same side... The default seems to be
1%... so 70% seems to be much more !
Almost double ! ;)
So here goes... to be continued... I fear this is gonna be an allocation
problem... like oh shit... it didn't fit ?! :)
I guess most important files should go first... then other files might
receive a little bit less or so to make it fit after all ;) Unless it gets
to bad ;)
Bye,
Skybuck.
Skybuck Flying
Hmm one last thing... I can't compress WinRar351.exe ofcourse... it needs to
remain the way it is... but the rest could do ! ;)
Bye,
Skybuck.
Skybuck Flying
Hmm that's kinda stupid...
The redundancy information seems to be limited to only 10% ?!?
That does make it a no brainer to try it out... but I wonder if it's gonna
work at all...
But might as well spent another sony dvd on it... since I got plenty of
those things...
Kinda interesting to see if it's gonna work or not...
Bye,
Skybuck.
Skybuck Flying
Ok,
Another bad toaster for the closet.
Conclusions:
1. DVD technology might be nice for audio, but is bad for data.
2. WinRar repair feature sux.
At least with these multiple bad toastest it's possible to still recover
some data...
Each DVD has certain files which work... which didn't work on others and
vice versa...
So with a bit of luck all might be recovered...
But for me this won't do... It's pretty crazy having to collect multiple
dvd's just to be able to restore
something successfull... just testing what's working and what's not working
costs a shit load of time !
So not gonna do that... for now I will have to rely on good faith and hoping
that some files are ok...
I think so since I already spent a shit load of time on testing it out with
WinRar's "test" feature which indicates crc32 failures on some files and
some not.
Kinda sux... I kinda regret buying 500 of these dvd's in the past... since
they so bad... or my drive bad... or the technology bad... who knows ;)
At least I can give them away for free... as audio dvd's when somebody has
audio dvd's... but I know of nobody that has audio dvd's lol ;) :)
Or it can keep trying and getting a good burn...
Maybe the verbatin disks will give better results but I doubt it...
I shall have to find another backup strategy in the future or maybe near
future...
Backing up everything to backup harddisks seems best to me...
Bye,
Skybuck.
Skybuck Flying
So many bad burns warrants a further investigation...
On the label on the sony cake... it says:
www.dvdrwservices.com
Which takes me to this compatibility list via the faq:
http://www.dvdrw.com/why/compatoverview.htm
Surprise Surprise ! The BenQ drive is not on the list ?!
Quite remarkable ?!
I feel a conspiracy theory coming on... or another explanation or even a
third explanation so there are now three possibilities:
Possibilities:
1. BenQ drive is utter crap.
2. Anybody know on compatibility list gets intensively fucked by some secret
code or procedure or whatever.
3. Sold media is crap or only suitable for their drives... which is pretty
much the same as step 2.
This kinda sux.
One last thing I could try is go over to my mother's place which has a cheap
HP computer... which also has a DVD drive... I don't know which one yet...
but maybe it's on the compatibility list... and then see if it does any
better burning...
This would require sending my stuff over via the internet... fortunately I
have my own protected file transfer tool... with a bit of help of remote
desktopping it should be able to do that and pull it off ! ;)
Then I can try a burn there... !
If that fails then I am gonna say **** it ! ;) :)
Last time I buy BenQ that's for sure... and last time I buy anything that's
not on some fucking compatibility list ?!
Be it cd, dvd, flash/ssd or whatever ?! ;)
Bye,
Skybuck.
Skybuck Flying
Quite remarkable ?!
Possibilities:
secret code or procedure or whatever.
Typo corrected, not that it matters much but ok:
2. Anybody not on compatibility list gets intensively fucked by some secret
Skybuck Flying
Actually since I had one good burn... I could simply take that DVD over
there and read it and such...
Add some file hashing info via e-mail just in case to tell if it read good
and it should be fine...
Then I can test if it can motherfucking read it... and then I can try and
re-burn it... to get some more duplicates ! ;)
One for the "safe/fault" and one for me ! ;) :)
Bye,
Skybuck =D
Skybuck Flying
Another company fucking skybuck up the ass:
I hate these motherfucking son of bitches !
This should be disallowed:
BenQ drives appear to be Philips drives !
I would have never bought it if I knew it had any Philips components in it
Philips = Always bad for computers at least.
But maybe cd and dvd technology is bad in general...
But still... this should be outlawed !
Selling under different names ! BAH !
Bye,
Skybuck.
Skybuck Flying
Maybe this failure log will be informative or helpfull for somebody out
there ?! ;)
Nero failure log 1:
Skybuck
1A20-8203-0139-2394-4252-0541*
1A41-70C1-M030-2482-5012-8431
1A42-0809-4030-2329-9503-7413
1A43-0609-4030-2312-3383-8659
1A44-0609-9130-2159-2652-6444
1A45-0609-9030-2448-3213-9734
1A46-70C1-M010-2526-3804-8791
1A47-0609-9030-2261-0221-1250
1A4A-0609-9130-2091-2397-1890
1A4C-80C1-M030-2400-5364-4495
1A4E-70C1-M030-2177-1260-3953
1A4K-90C1-M040-2753-1220-2853
1A4M-60C1-M080-2116-1504-4469
4A40-80C1-M050-2200-1340-5954
5A49-60C1-M020-2313-0112-7338
Windows XP 5.2
IA32
WinAspi: -
ahead WinASPI: File 'C:\Tools\Nero 6\nero\Wnaspi32.dll': Ver=2.0.1.74,
size=164112 bytes, created 10/26/2004 5:35:32 PM
Nero Version: 6.6.0.14
Internal Version: 6, 6, 0, 14d
(Nero Express)
Recorder: <BENQ DVD LS DW1655> Version: BCDB - HA 1 TA 0 -
6.6.0.14
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <BENQ DVD LS DW1655 >Version: BCDB - HA 1 TA 0 -
6.6.0.14
=== Scsi-Device-Map ===
CdRomPeripheral : BENQ DVD LS DW1655 atapi Port 1 ID 0
DMA: On
DiskPeripheral : HDS725050KLA360 nvata64 Port 2 ID 0
DMA: Off
DiskPeripheral : HDS725050KLA360 nvata64 Port 3 ID 0
DMA: Off
CdRomPeripheral : QZAZK KTINW5MV0 1.03 ato39a6y Port 4 ID 0
DMA: Off
=== CDRom-Device-Map ===
BENQ DVD LS DW1655 E: CDRom0
QZAZK KTINW5MV0 F: CDRom1
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 2047MB (2096564kB)
Free physical memory: 1240MB (1270416kB)
Memory in use : 39 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
30.10.2009
ISO compilation
2:20:53 AM #1 Text 0 File Isodoc.cpp, Line 6314
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
2:20:53 AM #2 Text 0 File Reader.cpp, Line 127
Reader running
2:20:53 AM #3 Text 0 File Writer.cpp, Line 122
Writer BENQ DVD LS DW1655 running
2:20:53 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3297
First writeable address = 0 (0x00000000)
2:20:53 AM #5 Text 0 File Burncd.cpp, Line 3230
Turn on Disc-At-Once, using DVD media
2:20:53 AM #6 Text 0 File DlgWaitCD.cpp, Line 267
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 1453919 (323:05.44, 2839MB)
2:20:53 AM #7 Text 0 File DlgWaitCD.cpp, Line 279
Write in overburning mode: NO (enabled: CD)
2:20:53 AM #8 Text 0 File DlgWaitCD.cpp, Line 2433
Recorder: BENQ DVD LS DW1655, Media type: DVD+R
2:20:53 AM #9 Text 0 File DlgWaitCD.cpp, Line 445=========================================
2:20:53 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 1453920 (1453920) = #1453920/323:5.45
relocatable, disc pos for caching/writing not required/ required, no
patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length
1453920 blocks [BENQ DVD LS DW1655]
2:20:53 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
Prepare recorder [BENQ DVD LS DW1655] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0
2977628160, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
1453920 | lead-out | 1 | 0x41 | 0x00
2:20:53 AM #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
2:20:54 AM #13 Text 0 File Burncd.cpp, Line 4114
Cache writing successful.
2:20:54 AM #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
2:20:54 AM #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 16x (22,160 KB/s)
2:20:54 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
Verifying disc position of item 0 (relocatable, disc pos, no patch infos,
orig at #0): write at #0
2:20:54 AM #17 SCSI -1066 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x05236200
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x12
0x00 0x00 0x00 0x00 0x24 0x00
2:20:54 AM #18 CDR -1207 File DVDR.cpp, Line 4946
Book Type automatically set to: Current recorder setting
2:20:54 AM #19 Text 0 File DVDPlusRW.cpp, Line 655
Start write address at LBA 0
DVD high compatibility mode: Yes
2:25:13 AM #20 Text 0 File WriterStatus.cpp, Line 116
<BENQ DVD LS DW1655 > start writing Lead-Out at LBA 1453920
(162F60h), lenght 0 blocks
2:25:13 AM #21 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
2:25:27 AM #22 Phase 37 File dlgbrnst.cpp, Line 1832
Burn process completed successfully at 16x (22,160 KB/s)
2:25:27 AM #23 Phase 78 File dlgbrnst.cpp, Line 1832
Data verification started
2:29:04 AM #24 Text 0 File ThreadedTransfer.cpp, Line 228
2:29:04 AM #25 SectorVerify 11 File Cdrdrv.cpp, Line 9853
Sector 173976 on disc has different content to source
2:29:04 AM #26 Phase 81 File dlgbrnst.cpp, Line 1832
Data verification failed
Existing drivers:
File 'Drivers\InCDfs.SYS': Ver=4, 3, 12, 0, size=99200 bytes, created
1/27/2005 6:08:02 PM (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDpass.SYS': Ver=4, 3, 12, 0, size=28928 bytes, created
1/27/2005 6:07:34 PM (InCD4 driver for win NT/2K/XP)
File 'Drivers\InCDrec.SYS': Ver=4, 3, 12, 0, size=8704 bytes, created
1/27/2005 6:08:08 PM (InCD4 driver for win NT/2K/XP)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon
Bye,
Skybuck.
Skybuck Flying
Failure log 2:
I hope those ain't activation keys... if so then **** nero you stupid dumb
son of bitches ! HAHA ! ;)
(Maybe nero don't work so well with BenQ drives who knows ?! ;) Maybe I
should give BenQ burning software a try or so ? hmmm...)
Skybuck
Windows XP 5.2
IA32
WinAspi: -
(Nero Express)
6.6.0.14
6.6.0.14
DMA: On
DMA: Off
DMA: Off
DMA: Off
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 1278MB (1308940kB)
Memory in use : 37 %
Use Inquiry : 1
30.10.2009
ISO compilation
3:49:00 AM #1 Text 0 File Isodoc.cpp, Line 6314
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
3:49:00 AM #2 Text 0 File Reader.cpp, Line 127
Reader running
3:49:00 AM #3 Text 0 File Writer.cpp, Line 122
3:49:00 AM #4 ISO9660GEN -11 File geniso.cpp, Line 3297
3:49:00 AM #5 Text 0 File Burncd.cpp, Line 3230
3:49:00 AM #6 Text 0 File DlgWaitCD.cpp, Line 267
3:49:00 AM #7 Text 0 File DlgWaitCD.cpp, Line 279
3:49:00 AM #8 Text 0 File DlgWaitCD.cpp, Line 2433
3:49:00 AM #9 Text 0 File DlgWaitCD.cpp, Line 445=========================================
3:49:00 AM #10 Text 0 File ThreadedTransferInterface.cpp, Line 830
patch infos
3:49:00 AM #11 Text 0 File ThreadedTransferInterface.cpp, Line 1043
DAO infos:
MCN: ""
Tracks 1 to 1:
2977628160, ISRC ""
DAO layout:
3:49:01 AM #12 Phase 24 File dlgbrnst.cpp, Line 1832
3:49:01 AM #13 Text 0 File Burncd.cpp, Line 4114
3:49:01 AM #14 Phase 25 File dlgbrnst.cpp, Line 1832
3:49:01 AM #15 Phase 36 File dlgbrnst.cpp, Line 1832
3:49:01 AM #16 Text 0 File ThreadedTransferInterface.cpp, Line 2643
3:49:01 AM #17 SCSI -1066 File Cdrdrv.cpp, Line 1182
Sense Code: 0x24
Sense Qual: 0x00
3:49:01 AM #18 CDR -1207 File DVDR.cpp, Line 4946
3:49:01 AM #19 Text 0 File DVDPlusRW.cpp, Line 655
3:53:14 AM #20 Text 0 File WriterStatus.cpp, Line 116
3:53:14 AM #21 Text 0 File ThreadedTransfer.cpp, Line 228
3:53:29 AM #22 Phase 37 File dlgbrnst.cpp, Line 1832
3:53:29 AM #23 Phase 78 File dlgbrnst.cpp, Line 1832
3:57:05 AM #24 Text 0 File ThreadedTransfer.cpp, Line 228
3:57:06 AM #25 SectorVerify 11 File Cdrdrv.cpp, Line 9853
Sector 369657 on disc has different content to source
3:57:06 AM #26 Phase 81 File dlgbrnst.cpp, Line 1832
Existing drivers:
Registry Keys:
Bye,
Skybuck.
Skybuck Flying
Failure log 2:
Actually "Nero Software" came with the BenQ drive... So I am already using
it... :(
Only other software for "dvd drives" that came with my PC/Drive(?) is WinDVD
suite...
Not sure if it's usuably for making Data DVD's... Hmm...
I'll give it a try.
Bye,
Skybuck.
Skybuck Flying
Also I wonder if Windows XP Pro x64 can simply burn stuff to DVD's... maybe
that will work...
I think windows media player might be able to do it... it seems to have some
burning capabilities or maybe that was a special program on somebody's
computer system ;) :)
For now I am gonna try WinDVD Creator 2... installed... bitched a bit about
64 bit... but seemed to install...
Needs a reboot... rebooting now...
Bye,
Skybuck.
Skybuck Flying
Well that was pretty confusing... Apperently WinDVD Creator 2 is part of a
WinDVD suite...
which is again called Intervideo launcher/whatever...
It's a "suite of 4 programs"
PhotoAlumb 1.0
DvdCopy 2.5
WinDVD Creator 2
Disc Master 2.5
The auto launcher didn't pop because I have it disabled... it says WinDVD
suite so I thought WinDVDCreator2 must be it... I thought wrong...
This time after reboot I decided to install the launcher as well and the
other 3 programs as well.. it looks handy...
I think Disc Master 2.5 is actually the thing I needed.
Again it requires a reboot...
Something interesting happened though... I think it fucked with my logon and
logoff scripts...
Those settings are probably gone... which means my file disk images weren't
be mounted properly...
So apperently these setup programs use logon scripts ?!? Me not sure yet...
not much of problem... just extra work for me... but could be problem if I
die and somebody else uses my computer they won't know how to fix it ! ;)
Unless I switch back to using batchfiles for startup folder.. but then log
off won't work... when user switching... so windows has lot's and lot's of
issues ! ;) but then... windows can also do much much much... probably much
more then ubuntu or any other operating system out there ?! But I might
wrong... but I don't think so... point of the story... so many
possitibilities... so many combinations... sooner or later it's gonna
trigger all kinds of untested unknown or ill known problems ! ;)
Rrrrrebooting.. the dreaded reboot.
Bye,
Skybuck.
Skybuck Flying
BY THE WAY this software came with my asus motherboard... it says it only
works with asus motherboards !
I feel like I own something special !!! Big fucking whoopie ! ;) :)
Ok time to give it a try ! ;) :)
This could rule out if it's a nero issue or not...
This gonna be interesting... I wonder what it's gui will be like...
Bye,
Skybuck.
Skybuck Flying
Oh by the way.. the logon and logoff script is working again... maybe the
first time it just took a bit of time or something... or maybe it restored
it... I don't know...
Ok time to test "Intervideo WinDVD Suite, Disc Master 2.5 that only works on
Asus motherboards" !
That's a whole mouth of come for you ! ;) :)
Bye,
Skybuck LOL.
CellShocked
better than WinRar.
Bye,
Skybuck.
The tools that are in place are beyond the comprehension of Usenet group
abusing retards like you.
AFTER you find out what posting conventions and protocols are, and AFTER
you start following them, you MIGHT get better answers to your wildly
STUPID question from the perspective of nearly all the groups you have
decided to INVADE with your stupid horseshit.
