50 Gigohm Resistor?
I had the experience of looking at a circuit board with a resistor
marked 50G, indicating 50,000 Megohms. One of the resistor leads was
mounted on a teflon pad since the resistance of the board would
probably be a good portion of 50 Gigs.
Any idea what application would make use of a resistor so high?
-Bill
W
Winfield Hill
was mounted on a teflon pad since the resistance of the board
would probably be a good portion of 50 Gigs.
To work with small currents, of course. I have resistors to
1T in my inventory. When using these I find that air is better
than teflon.
Sometimes one has to replace the resistor with a capacitor, if
you get my drift.
Steve Noll
-Bill
One application is a feedback resistor for a transimpedance amp for a
photodiode.
Steve Noll | The Used Equipment Dealer Directory:
| http://www.big-list.com
| Peltier Information Directory:
| http://www.peltier-info.com
Joerg
Hello Win,
than teflon.
And after turning it on, don't breathe :)
Regards, Joerg
Joerg
Wouldn't that be more than the resistance of air?
I think your reading it wrong. I think the highest resistors only make
it to 10's of Meg, and not 1000's
15M, occasionally 18M is usually the highest readily available value.
Anything higher I'd count under boutique parts. Might be needed for
highly specialized measurements but should not be used in day to day
designs IMHO.
Regards, Joerg
K
Ken Smith
photodiode.[/QUOTE]
I can imagine a situation where you'd want one that high on a
transimpedance amp. Consider an op-amp with a 1nA bias current.
50E9 * 1E-9 = 50V
That's more offset voltage than the Vcc limit of most op-amps.
K
Ken Smith
Phil Allison said:
Condenser microphones typically use 1Gohm resistors to bias the capsule and
FET preamp.
I know one design uses quite a bit more than even that.
Phil Allison
"Ken Smith"
Phil Allison
** How mysterious .........
What does it take to get you to spill the beans ??
........ Phil
Steve Noll
photodiode.
50E9 * 1E-9 = 50V
--[/QUOTE]
I've built photodiode transimpedance amps using as high as 100G-ohm
resistors before. It takes some care, but is definitely do-able.
It's interesting and dramatic to watch the offsets decrease when the
box containing the circuit is flushed with dry nitrogen.
Sven Wilhelmsson
Joerg said:
Hello Win,
Regards, Joerg
But you can look! 1V/1Tohm = 6 Millions electrons per s.
Your eyes are sensitive to a few hundreds photons per s.
For a particle physicist 1 Tohm is shortcut.
Robert Baer
than teflon.
you get my drift.
Punny!
Robert Baer
http://www.interfacebus.com/resistor_table.html
Of the more common hi-R resistors, note that DigiKey and Mouser carry
the various Ohmite series; to 5,000Megs and 20KV rating at 1% and 5%.
...and Ohmite is not the only maker...
Michael A. Terrell
designs IMHO.
Regards, Joerg
22 meg was readily available in the old carbon comp days in 5%, 10%
and 20%.
prove it.
Member of DAV #85.
Michael A. Terrell
Central Florida
Roger Hamlett
and 20%.
Meggitt electronic components, do 0805 SMD cermet resistors, in a range
from 15M, to 50G. Maybe even further than this, but this is the highest I
have used. The tolerance, is only 30% on the higher values, and with
slightly worse than normal temperature coefficients, but readily available
(at least in the UK - both RS, and Farnell do them).
Best Wishes
