Not really; make sure they clean the board - the so-called "no clean"
is sheist.
ITYM "scheiß"
Either way, no-clean flux is no fluxxing good.
I had to have a board very clean due to circuit layout. Any thing on the board had an
effect. The trouble with the clean flux, the water spray cleaning, made
caps absorb moisture which then had to be baked. Addition cleaning under the chips
was necessary because the cleaning process was not sufficient. Some
flux cleaners ended up causing problems with some caps. Basic alcohol
was necessary.
I once worked at a place where they had a huge ultrasonic cleaner -
once when I saw an anomalous 40 KHz superimposed on whatever I was
scoping, one of the other techs said, "That's Branson noise", which
meant it was from the Branson ultrasonic cleaner. I also seem to remember
"vapor degreasing", where they have a tank of hot freon, and when you'd
lower the board into the vapor, the freon vapor would condense on the
relatively cool board and when it ran off, it rinsed off all of the
residue with it.
They might have used them in conjunction, like dip in the US tank,
in liquid freon, then rinse in the vapor or something like that. It was
very long ago.
Cheers!
Rich
