58 watt Fluorescent Lamps Power Requirement
martin
Please excuse the elementary question, but with
a 5 foot fluorescent light the LPF and HPF types,
(with and without a fitted power correction capacitor).
On a conventional domestic supply meter, which would
register the higher power consumption or would they
be the same.
Martin
Andrew Gabriel
be the same.
They would be the same.
LPF would draw approx twice the current though, which
you have to bear in mind when working out circuit load
and fusing, particularly when using several such fittings.
James Sweet
be the same.
Martin
Depends on what the meter measures. USA residential meters measure true
power, in other words, HPF and LPF will cost you the same, although it's
always best to strive for as close to unity as possible, as it reduces waste
in the resistance of the wire. Someone told me that power meters in some
countries measure apparent power, I don't know if this is true or not, but
if it is, then HPF will cost approximately half.
Andrew Gabriel
UK residential customers have to be metered on true power.
Power companies are allowed to use other schemes for
non-residential customers.
| In article <mYCGj.4467$Ew5.2750@trnddc04>,
So you can have a power factor of 0.1 at home and not be dinged for it?
K
krw
The US is the same. Watt-hour meters measure energy.
Andrew Gabriel
Correct.
The EU has/is imposing minimum power factors on various volume
electrical goods over certain power ratings.
