7 segment pressure gauge help? Modify voltmeter from Projects?
johndeverill
Nov 16, 2004
40
Relating to my other post. I have a pressure transducer that outputs 0-100mV for 0-30psi. What I would like to do is create a 7 segment led (well double/triple) figure type that would display 0-30 for 0-100mV being supplied.
If anyone could point me in the right direction on this one that would be great. Even if you just know a good site that would be fantastic.
Many thanks
John
MP1
Dec 7, 2003
3,399
Look in our projects section for the digital voltmeter project. This sounds like it is exactly what you want.
MP
johndeverill
Nov 16, 2004
40
Hi MP,
I've taken a look and I can see it could display the voltage for me fine. The issue I have is that I want to display 0-30 instead of 0-100mV so that it displays the pressure. Can you point me in the right direction so that I can do the conversion?
Many Thanks
John
MP1
Dec 7, 2003
3,399
Hi John,
The data sheet has information regarding resistor changes needed for different ranges. This is a pretty versatile chip.
MP
johndeverill
Nov 16, 2004
40
Hi MP,
I may have missed the point here, you'll have to excuse me as I'm quite new to electronics but learning......slowly but surely!!
I actually think the input will be 0-330mV for a 0-30psi range off the tranducer. The thing is if i set full scale to be 330mV etc the unit will read 99. What I would like it to read is 30. Can you advise on this?
Many thanks
John
johndeverill
Nov 16, 2004
40
Hmmmm,
Just been thinking and I may have answered my question.
Is it just a matter of changing the resistance to alter Vref so that when the transduer is at full scale the voltmeter is only displaying 30 on the LED's?
John
