7912 as negative voltage regulator issue
Kaash
Aug 16, 2013
10
hi guys..
im using 7912 as negative voltage regulator but when i connected it with 12v or 20v supply it got very hot without any output voltage.
i wasted 4-5 regulators but get no output -12, is there other any way to connect it?
help plz.
thanks
You have the ground and power reversed. For a negative regulator the ground has to be higher than the input.
Edited: You also need the capacitors on the input and output. See the datasheet.
Look up the datasheet. It has a sample circuit.
