8pins IC holder datasheet
only_lonely
Jul 30, 2004
92
i need a 8pins IC holder datasheet for my project
i need it for my CADCAM drawing.i want to create a SOIC to DIL socket for my microcontroller chip atTINY15L(8pins).
the image below is 16pins.
anyboby can help me?THANKS>>>
only_lonely
Jul 30, 2004
92
i want to fabricate a SOIC to DIL 8pins socket for my attiny chip on PCB.but i don't hows the schematic look like.can somebody help me ...raftly draw the diagram for me...the image look like below..but it is 16pins.
or somebody know how to use eagle?because i found it in atmel lib.but i don't how to copy it to my blank project folder..i don't how to use eagle.
pls help..THANKS!!!
MP1
Dec 7, 2003
3,399
It is much better when you can make your own.
In eagle, you create a blank schematic, then use EDIT, and ADD to retrieve a library part. Put both parts on the schematic and run the wires from pins on one to the other. Pin 1 to Pin1, Pin 2 to Pin 2, etc.
After this, there is an icon at the top of the page to turn it into a board layout. Just move the parts onto the board where you want them in this screen. You can run the autorouter from the menu on the top. It is under TOOLS, and then AUTO.
MP
MP1
Dec 7, 2003
3,399
If you still need help with this in eagle, let me know the two library parts you want to combine and I will help you with it.
MP
only_lonely
Jul 30, 2004
92
the chip holder now i have is a normal 8pins holder...for the ic chip(74xx).
i follow MP instruction..first create a schematic..edit>add>atmel>attiny15L>...i don't how to continue...i want my circuit like this
THANKS for your help!!
MP1
Dec 7, 2003
3,399
I just posted the answer to your other post. It looks like you are duplicating posts.
Either IC package will be fine and yes pin 1 to pin 1, 2 to 2, etc.
MP
