90 degrees phase shift
jtamminen
May 3, 2006
9
I have a sine-wave input, 45 to 60Hz, few hundred millivolts.
The sine wave might have some distorsions now and then, and these distorsions needs to be replicated at output. (kind of mains-current monitoring device).
The input varies from zero to some voltage, and is amplified to a 0-5volt level.
That is the easy part.. now the problem:
How could I "lag" the phase 90 degrees with analog design?
The frequency is as said, 45 to 60Hz, but a constant in one application. It is possible to use different components with different frequency..
I know it is easy to do with a micro, A/D and D/A along with a ring-buffer, but I need to avoid digital logic here...
Anyone able to give me a hint how this might be done?  The output should be as close to input wave-shape as possible.
Hope You understand my question, I'm not native english.
slackjack
Nov 2, 2005
177
Well a wave the lags a sine wave by 90 degrees is a -cosine wave. When we integrate a sine wave, we get a -cosine wave. To do this you could use an operational amplifer configured as an integrator. The output voltage is:
Notice that the integral has a negative (-) sign. Well the negative cosine and the negative integral will cancel out to give a postive output. To get the -cosine, feed the output to an invertor with a gain of 1.
I'm not sure how good this method is at replicating distortions though
audioguru2
Apr 6, 2004
12,026
No. An integrator is also a lowpass filter and will reduce distortion.
Use an Allpass filter with its amount of phase-shift adjustable for the frequency.
MP1
Dec 7, 2003
3,399
Here is how it is done for the audio range. Of course, this is for a sound effect. Add or take away phase shift stages as needed.
MP
jtamminen
May 3, 2006
9
MP
Thank You, I believe this will solve my problem!
