A question about "output stages".
larb
Jan 5, 2024
6
Please pardon a beginner's question. I am working on a vacuum tube amplifier and I would imagine that it would also apply to a semiconductor amplifier as well. What is the difference between a single node output stage compared to a two node output stage. I have a schematic for this amp and I need to determine which one it is. Thanks in advance for any guidance given!
larb
Jan 5, 2024
6
I apologize crutschow but I don't have a schematic for this amp. I was just wanting to know the meaning of "single node output stage". In speaking with an engineer I was told that the amp had a "single node output section", I should have asked him for clarification. The amp in question is similar to a Vox AC4 guitar amplifier which was popular in the early 1960's.
Delta Prime
Jul 29, 2020
2,996
Sorry, my friend you must be more concise.
This is the best I can do. I cannot answer your question. it will only cause you more confusion to give you multiple answers see Here.
AnalogKid
Jun 10, 2015
3,058
My g.u.e.s.s is that he is referring to a class A, single tube versus a class AB, two-tube push-pull arrangement. A push-pull output stage can be much more efficient, and present a symmetrical and lower output impedance to the load.
ak
