A quicker LM393 ?
Martin Griffith
Oh crikey, just remembered ! A quasi-random unconnected thought. Ages back you
mentioned an outfit that had a compiler for the former 'Alesis' DSP chips.
I thought I'd bookmarked it but can't find it. Can you refresh my memory ?
Graham
wavefrontsemi
available from profusionplc.com
But the forum on wavefront has closed, and they no longer have Dice11
on the website.
seems a bit worrying
Martin
John Larkin
Which LVDS parts do you use?
Several of the National 5 volt and 3.3 volt parts, like DS90LV018 and
DS90C402.
The Fairchild FIN1101 is lvds-to-lvds and is blinding fast. It can be
handy if you treat it as an LVDS-output comparator. It's handy for
distributing fpga clocks, too.
Most LVDS-to-ttl converters will work fine with one input grounded,
even though that's not a legal common-mode voltage. You can make a
nice LC oscillator with a tank to ground and a little feedback.
John
John Fields
Looking for an inexpensive commodity dual comparator that's a little quicker
than the ubiquitous LM393.
Suggestions ?
Joseph H Allen
Suggestions ?
Along the same lines as the LVDS receiver.. how about an RS-422 receiver
like an SN75173 or 26LS32? TTL outputs, -12V to 12V input range (even with
a single 5V supply), should work up to about 15 MHz. Low offset voltage?
Forget about it (in fact it has 50 mV of hysteresis), but perhaps it does
not matter for you.
John Larkin
What's this, the winner of one of those unreadable-C contests?
int
a[1817];main(z,p,q,r){for(p=80;q+p-80;p-=2*a[p])for(z=9;z--;)q=3&(r=time(0)
+r*57)/7,q=q?q-1?q-2?1-p%79?-1:0:p%79-77?1:0:p<1659?79:0:p>158?-79:0,q?!a[p+q*2
]?a[p+=a[p+=q]=q]=q:0:0;for(;q++-1817;)printf(q%79?"%c":"%c\n","
#"[!a[q-1]]);}
No wonder they call it "code"!
John
Joseph H Allen
Another option: AD8561 (an upgrade of LT1016), although it's a single, not a
dual. I've had great success using these as very low jitter video sync
separators in the past (for when an LM1881 just will not do).
Compile it! :)
Eeyore
LT and AD ?
Sounds expensive to me.
Graham
Spehro Pefhany
On Mon, 19 Nov 2007 03:23:24 +0000 (UTC), the renowned
Compile it! :)
A puzzle within a puzzle. Cute.
Best regards,
Spehro Pefhany
John Devereux
Compile it! :)
/* [email protected] AB1GO */ /* Joseph H. Allen */
int a[1817];main(z,p,q,r){for(p=80;q+p-80;p-=2*a[p])for(z=9;z--;)q=3&(r=time(0)
]?a[p+=a[p+=q]=q]=q:0:0;for(;q++-1817;)printf(q%79?"%c":"%c\n"," #"[!a[q-1]]);}
Reminds me of my 1-line BASIC program to plot a sine wave, on my UK101
kit computer - it only had 768 bytes of free RAM so that was about all
it could manage.
W
Winfield
Eeyore said:
LT and AD ?
Graham
Let me mention again, in case you missed it, Maxim's
MAX942 is about 8x faster than the LM393, about 80ns
vs. 750/1250ns for 5mV overdrive. Same dual pinout,
inputs work to ground, etc. Note, it has active-pullup
outputs. Newark (Farnell) has the miniDIP package in
stock, $3.62 ea. Or get free samples from Maxim.
Eeyore
Thanks for that Win, but it looks to me like the LM319 fits the bill for just
29p @ 1 off from Farnell.
Inputs working to (and even just below) ground would have been nice. I'll need
to think around that.
Graham
W
Winfield Hill
Graham
Oh, I assumed you needed the same package size
and pinout as the LM393. There are all kinds of
possibilities if you give up that requirement.
Eeyore
Just the same function. It's not a retrofit so allcomers are welcome.
Graham
Paul Burke
It also oscillates at the slightest provocation, so your layout
(especially lengths of input tracks) will have to be spot on. I fell
over this badly once- the more so because the prototype I tested it on
behaved perfectly, it was only the production units that wobbled.
