Brad Hogan
- Jan 1, 1970
- 0
It seems to be a device to be built into or retrofitted into an
appliance, as is implied in the video, and as such, the only way I can
think it would work is to "learn" the typical current/voltage usage
patterns of the device its connected to - and if there is any sudden
change in these patterns- (that 'looks' consistent with human contact
or "hazardous" leakage for example?) that seems suss, then it shuts
off the power.
you cant do that for $1.50
You could do it for $1000.
If this is the case, (its in the appliance) then surely it would
provide no protection for the cord, plug etc of that appliance, and
these probably need to be protected a lot more than the innards of the
appliance, as cords are so easily damaged, and often touched by the
consumer ?
true.
for that matter - if his magic device is INSIDE the
hairdryer - and the dryer is then thrown into the bathwater - it might
very well do a great job of cutting the power to the dryer's
internals, but how is it going to stop the current still flowing down
the cord and into his device ?
true, its pointless . they wont build the hair dryer to do it.
I also find it strange his implication that appliances with 2 pin
plugs "seem to be unable to work effectively with an RCD compared to 3
pin ones".
He would have tested two wire hair dryer in a ceramic vanity basin with
plasic pipes.
Do you see any thing for an RCD to detect ??
Now take a three wire hair dryer. There's water between active and earth.
I see an RCD trigger.
The protex is only working because its requiring the third wire in the hair
dryer.
Stick to the RCD and combine the protex into it.
That would make it a "RCSVD " Residual current or stray voltage device.
As I see it - an RCD will work just as well with 2 pin as
3 to protect a human body from electric shock, as long as you have an
earth connection, (ie: the ground you are standing on) and if you
didnt have a ground connection to your body when you touched the
active lead, you aren't going to get a shock anyway, unless you grab
both active and neutral.
yes, quite correct.
I didn't see the process where the panel interviewed him on the device
- and there are no details even remotely on how it works, either on
his website or the URL you gave above. In fact the whole site seems
to totally avoid the theory of operation and instead give tons of
vague"consumer' type information about how wonderful it is - and will
save the world etc etc.
Yeah he will save the world, but only if the RCD disappears.
all mass produced things cost $1.50 to make. whats the actual sale price
also, how many cases would there be of people accidentally coming into
contact with both active and neutral connections *simultaneously* in
domestic situations ? remember that unless you grab both of them at
the same time, (within the trip time of the RCD) then the one you
touch first - will set the RCD off and stop the current flow anyway)
none at all.
this leads to the result that the protex is not as good an RCD,
you should have RCD's first and then protex if you still want more
protection.
The protex may as well be added to the function of the RCD
RCSVD.. Residual Current Stray Voltage Device.
