Hi guys,
I am trying to trigger a 230vac circuit off of a 24vac circuit. I thought the easiest way to do this would be with a relay as it allowed for sufficient current on the 230vac side.
I got a relay with a 24vac coil, but with the coil resistance of 180 ohm it brought the signal voltage down to 12vac
I also have another relay with a 12vac coil but the coil resistance is only 46 ohm meaning the circuit only drops to 16vac. I added a 100ohm resistor which brought the voltage down within range for the relay to operate correctly but the resistor burnt out.
Am I going about this the best way and i just need to up the size of my resistor (was only a 1/4watt or is there a better idea?
