raycenteno
- Sep 13, 2005
- 7
- Joined
- Sep 13, 2005
- Messages
- 7
Hopefully some of you can bring some insight on what i could do to this project i wish to work on. I am trying to power up an ac motor with an inverter, but it just does not seem to work.
Here are the specs: the motor- 1hp 115vac 60 hz 11a. the inverter-12vdc to 120vac 2kwatts max 4k, mod sinewave.
I definately must be missing something somewhere, the inverter powers up to about 1300 watts on its led meter, the motor tries to turn but within about 3 secs the inverter alarm goes off and shuts off.
I did try manually to turn it and then flip the switcch, but i get the same result.
So far i have tried 4 differ motors.
(1) the one i mentioned, it is treadmill motor
(2) a frigidaire dryer motor rated at 1/3 hp
(3) a dayton motor rated 1/2 hp, this one only had 2 connectors for it
(4) an old leeson, a 1hp motor that has a hump on it, it's capacitor, this motor actually started and was prob about 80 rpm when the inverter shut off.
I was thinking about transformers, maybe if I am able to find one that has a 1 to 1 ratio, but i am not sure if this would be my answer.
I also thought maybe the inverter is not producing the right hz, but i am not sure how to fix this and i do not have the equipment to check the hz.
Can anyone help?
Can anyone help?
